Belkin N300 Router
- Re: Belkin N300 Router
Belkin N300 Router
27-01-2013 4:24 PM
Sorry for being a dummy..
Is this compatible with 21CN exchange? - the techy bit on the Belkin website says it has an 'integrated ADSL2+ modem' but on the box it only mentions ADSL.
Message 1 of 5
(1,120 Views)
4 REPLIES 4
27-01-2013 4:57 PM
I would expect so but if you post the model number you should get a better answer.
Message 2 of 5
(602 Views)
27-01-2013 5:36 PM
Thanks it's a F9J1002v1
Message 3 of 5
(602 Views)
27-01-2013 5:42 PM
Yes, it does - I have this as a spare router and it works fine
Message 4 of 5
(602 Views)
27-01-2013 5:53 PM
Thank you for your help, that's good to know.
Message 5 of 5
(602 Views)
