Belkin N150
- Belkin N150
Belkin N150
20-11-2010 4:19 PM
Hi
Can you tell me if this router will work ok with plusnet?
Message 1 of 5
(1,654 Views)
4 REPLIES 4
Re: Belkin N150
20-11-2010 4:32 PM
if its this one http://www.pcworld.co.uk/gbuk/belkin-n150-enhanced-wireless-router-02380497-pdt.html
then NO it won't , that's a cable router, but this one http://www.pcworld.co.uk/gbuk/belkin-f6d4630uk4a-wireless-adsl-router-802-11-n-4-port-switch-0238048... will work.
Message 2 of 5
(734 Views)
Re: Belkin N150
20-11-2010 5:09 PM
Thanks for the help.
It's actually this one.
BELKIN F7D1401UK
http://www.comet.co.uk/p/BT-Landline-Routers/buy-BELKIN-F7D1401UK-BT-Landline-Router/669415
Do you know if it will be ok?
BELKIN F7D1401UK
Message 3 of 5
(734 Views)
Re: Belkin N150
20-11-2010 5:32 PM
That one will work fine.
If life gives you lemons, make lemonade.
Message 4 of 5
(734 Views)
Re: Belkin N150
20-11-2010 6:05 PM
Cheers Steve.
Message 5 of 5
(734 Views)
