Been banded again
zpeterk
Been banded again
Is there any particular reason why my line keeps getting banded?
9 REPLIES 9
Fixes: 357
Re: Been banded again
Most likely because there is something wrong with it.
adamwalker
Fixes: 223
Hi @zpeterk I've just had a look into this for you and have put a DLM reset through as line tests don't show any obvious issues. It should take effect within the next 24 hours, let us know how things go.
 Adam Walker
zpeterk
Thanks Adam
After reset I was getting A LOT of resyncs I think it has gone back to being banded again.
Fixes: 357
@zpeterk Sounds like further investigation is required?
Fixes: 1,653
Yeah looking at the connection graph below, there does seem to be an underlying issue.
Line tests aren't showing the cause for this so we'd likely need to arrange an engineer visit to investigate further, but first is your router plugged into the master telephone socket with no extension cabling between the socket and router?
If that's the case, when could you be available for a visit? The engineers are available weekday timeslots (and occasionally Saturday's) of 8am to 1pm or 1pm to 6pm.
zpeterk
Modem is plugged directly in to master socket, there are no extensions or telephones connected at all.
I can be at home as required with notice.
pvmb
Seasoned Pro
Fixes: 12
It ain't necessarily so🤔
P.S. My ADSL line is "banded", but there isn't anything wrong with it.
RealAleMadrid
Fixes: 68
@pvmb  Looking at message #6 there is definitely something wrong with that line. It's been banded because it's rubbish, your own situation may well be different and the line functions Ok with banding in place.
Fixes: 1,653
Okay, I've booked the engineer visit for this Wednesday 10th August between 8am to 1pm.
Let me know how you get on. Smiley
