Bandwidth UP Capped at 443kbps with SNR of 32.6dB
SoFarSoGood
Hi all
Only joined yesterday and would appreciate your help/comments on the following:-
1) My Bandwidth UP appears to be capped at 443kbps with a SNR of 32.6dB.
Is it possible to uncap it and how do I go about this please?
2) Output Power DOWN appears to be 0.0 dBm.
Is this correct/ok or does something need to be changed?
3) With my previous ISP I was on Fastpath.
Do I need to wait until the end of the line-training period to request a change to Fastpath?
If so, can I request the change via this forum?
I hope I have posted in the correct section and thank you for your help.
Fixes: 61
Re: Bandwidth UP Capped at 443kbps with SNR of 32.6dB
Raise a ticket asking for it to be uncapped which will probably be quicker given the Easter weekend
Output power is a router reporting foible and should be ignored
SoFarSoGood
Quote from: Oldjim
Hi Jim
Thanks for your reply.
Silly question but, how do I raise a ticket?
Could you point me to a link as I could not see how to do this when I looked yesterday.
Mattz0r
Hey there SoFarSoGood,
I've saved you the trouble Cheesy
The order to uncap your upload speed has been placed, due to complete on 03/04/13
In future reference: http://contactus.plus.net - Log-in, then select the correct section to raise your ticket to, and away you go!
Regards,
Matt
SoFarSoGood
Hi Matt
That's amazing service, particularly as it's Easter Sunday.
Very much appreciated and thanks for the link.
dick:quote
Mattz0r
You're very welcome Smiley
We aim to please Wink
Enjoy the rest of your day =]
Matt
