Banded / VDSL reset
richardjerome
Banded / VDSL reset
Hi - is it possible to get a DLM reset on VDSL2 line, or have check whether I've been unintentionally banded?
Have always had 73999 or 79999 - I'm about 100m from cabinet - but have seem to be stuck on 66997/SNR=9 for last few weeks. Attainable is ~87000. Low VDSL Range B is 74, and I'm below the handback is 67 now.
Nothing has been changed at my end, and quiet line test OK.
Running a Draytek 2760/DrayOS, straight into a new-ish Master 5C.
Thanks,
Rich
2 REPLIES 2
Marsh
Fixes: 41
Re: Banded / VDSL reset
Hey @richardjerome,
I have had a look at the line and I can see it has been banded. I have performed a DLM reset on the line it could take a couple of days for the speeds to go back to normal, but if the issue persists, please let me know, and I can take another look into it
Josh
richardjerome
Much appreciated, thank you!
///Rich
