Banded IP profile
- Banded IP profile
Banded IP profile
28-03-2013 12:11 PM
here are my router stats as of now-
Uptime: 2 days, 7:33:16
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 864 / 13,248
Bandwidth (Up/Down) [kbps/kbps]: 446 / 2,266
Data Transferred (Sent/Received) [MB/GB]: 297.80 / 4.91
Output Power (Up/Down) [dBm]: 12.0 / 18.0
Line Attenuation (Up/Down) [dB]: 18.5 / 29.5
SN Margin (Up/Down) [dB]: 27.0 / 14.0
Loss of Signal (Local/Remote): 65,538 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 65,538 / 0
FEC Errors (Up/Down): 22 / 25,152
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
Re: Banded IP profile
28-03-2013 1:47 PM
I'm sorry you couldn't get that change done on the phone, that shouldn't have been a problem - sorry for that!
29-03-2013 12:31 AM
router stats as of now -
DSL Connection
Link Information
Uptime: 0 days, 0:22:59
Maximum Bandwidth (Up/Down) [kbps/kbps]: 864 / 14,176
Bandwidth (Up/Down) [kbps/kbps]: 446 / 2,266 * STILL BANDED *
Data Transferred (Sent/Received) [MB/MB]: 1.12 / 5.35
SN Margin (Up/Down) [dB]: 26.5 / 14.0
FEC Errors (Up/Down): 0 / 104
29-03-2013 10:54 AM
Really sorry about that, I misread your post. I'm just working on this now for you. Looks as though the SNR Reset hasn't gone through.
29-03-2013 11:25 AM
Really sorry I can't do that sooner for you.
31-03-2013 1:41 PM
01-04-2013 9:06 AM
01-04-2013 9:38 AM
routerstats as of now Uptime: 0 days, 0:28:20
Maximum Bandwidth (Up/Down) [kbps/kbps]: 864 / 13,892
Bandwidth (Up/Down) [kbps/kbps]: 446 / 12,832
Data Transferred (Sent/Received) [MB/MB]: 4.62 / 19.02
Output Power (Up/Down) [dBm]: 12.0 / 19.5
SN Margin (Up/Down) [dB]: 26.5 / 6.0
Loss of Signal (Local/Remote): 65,537 / 0
Error Seconds (Local/Remote): 65,537 / 0
FEC Errors (Up/Down): 0 / 27,482
CRC Errors (Up/Down): 0 / 5
HEC Errors (Up/Down): 0 / 14
speedtest net results -
http://www.speedtest.net/result/2614317695.png
Massive apoligies for being a pain.....
01-04-2013 9:43 AM
If you could log into your router and 'Disconnect' and 'Connect' again, it should update the Speed Profile which I've changed on our end so you see the speeds you should be getting.
01-04-2013 9:49 AM
speed of 11meg now, your a legend Chris many thanks again...
