Bad value for money
- Bad value for money
Bad value for money
20-01-2008 7:56 PM
So over the past 8 months, my speed has dropped by 60%.
Now I'm well aware that this will not be clasiified as a fault until the speed goes below 0.5, but come on, I'm paying £15 per month for this?
I could get this speed for free!
Is there a good reason to stay?
Re: Bad value for money
20-01-2008 8:17 PM
Have you had a look at James' post on speed issues? It is a line issue rather than an account (i.e. Plusnet) issue that's slowing your connection and there are a lot of good tips that will help you to increase the speed. If there's nothing in there that makes any difference please let us know.
21-01-2008 8:14 AM
If you post here your router stats and a BT Speedtest result will give us some clue.
SW.
3Mb FTTC
21-01-2008 9:08 AM
Could you possibly connect to the internet for me? I've tried having a look at your line but because you're offline, I';m not really able to get much information.
As for reasons to stay rather than moving to a free** supplier then I'd give you referrals, quality customer support and of course the Comms Team. But it does just depend on how cost focussed your needs are. Obviously if you refer enough customers then your connection will essentially be free, but that's a different conversation.
21-01-2008 10:50 AM
Quote from: Jameseh ...As for reasons to stay rather than moving to a free** supplier then I'd give you referrals, quality customer support and of course the Comms Team...
Not forgetting modesty
Seriously there are added benefits such as free fixed IP etc...
Like already said above, if your problem is the local loop or beyond to BT backbone then changing ISP won't make a difference unless perhaps you switch to cable; but does anyone really want NTL/Telewest known as Virgin?
21-01-2008 6:38 PM
21-01-2008 6:53 PM
21-01-2008 8:06 PM
Date Speed Achieved (kbps)
20-01-2008 19:33:36 149374
20-01-2008 19:33:10 0
20-01-2008 15:27:29 1632.9
20-01-2008 15:26:58 174298
19-01-2008 14:16:39 1366.5
18-12-2007 12:58:53 0
18-12-2007 12:58:40 0
18-12-2007 12:58:23 0
15-12-2007 11:26:51 1928.4
15-12-2007 11:26:32 1925.1
15-12-2007 11:26:06 1936.2
15-12-2007 11:25:24 196608
09-08-2007 20:40:51 2337
09-08-2007 20:39:36 0
09-08-2007 20:39:16 0
25-07-2007 20:16:22 225468
25-07-2007 20:14:48 0
25-07-2007 20:13:39 2813.8
25-07-2007 20:12:42 2824.8
25-07-2007 20:12:04 0
As for staying, I'm a non-techie, so no idea if a fixed IP is good or bad, and as for a portal, I don't do anything on my account anyway - all that happens is I get hit for £15 every month.
21-01-2008 8:10 PM
Thats notoriously unreliable - try the new one at www.mybroadbandspeed.co.uk and see what you get.
Reading what you can from the successful ones you've managed, it looks as if your speed has improved over the times recorced - but as I say, the portal one is a bit flaky.
21-01-2008 8:20 PM
my result, I have just tried the new one and no real change
19-01-2008 20:17:44 1574.5
19-01-2008 14:38:04 551.3
13-01-2008 21:34:00 458.7
16-12-2007 21:33:39 1288.8
15-12-2007 17:33:46 120.5
12-12-2007 21:01:08 1237.6
02-12-2007 19:12:46 1467.1
02-12-2007 19:11:23 1412.1
02-12-2007 07:03:07 1048.3
28-11-2007 18:23:59 1459.1
27-11-2007 21:53:58 1517.6
27-11-2007 18:40:50 1434.9
26-11-2007 20:57:50 500.2
11-10-2007 22:36:38 2735.5
02-10-2007 12:52:38 2431.1
09-09-2007 12:47:05 2632.3
04-09-2007 07:19:17 1434.8
17-08-2007 08:50:08 2828.7
21-01-2008 10:38 PM
Some things for you to do, then we may have a clue:
[1] Can you tell us what it says on https://portal.plus.net/my.html?action=data_transfer_speed ? It should be a number in the range 500 to 8000.
[2] Run a BT speedtest, run it 3 to 5 times and post all the results here. You need to persevere as it is busy!
[3] Type your exchange name into http://usertools.plus.net/exchanges/ does it show any Red icons for your exchange?
[4] What is the make/model of your router or USB modem you use to make the ADSL connection to the internet?
SW.
3Mb FTTC
21-01-2008 11:19 PM
BT Voyager 2110
No problems - Braintree exchange
What do you mean by BT Speed test?
21-01-2008 23:07:23 1444.9
21-01-2008 23:06:51 1621
21-01-2008 23:05:49 1506.8
21-01-2008 23:05:49 1462.4
21-01-2008 23:04:26 1187.8
21-01-2008 23:01:59 132.5
21-01-2008 20:16:55 423.2
21-01-2008 20:16:04 443
Test take recently , the real bad one (132.5) was on an Archos 705 right next to router
I Have two laptops, one xp with its own wi and one Win 98 with a BT PCI card, both give similar results
as the crow flies I am less than 1Km from the exchange and can see it
21-01-2008 11:24 PM
21-01-2008 11:56 PM
time for bed Will try again in the morning
22-01-2008 7:21 AM
