turn on suggestions
Bad service once again
- Bad service once again
23-07-2014 2:16 PM
Results Image not loaded
1. Best Effort Test: -provides background information.
Download Speed
34.64 Mbps
0 Mbps 77.44 Mbps
Max Achievable Speed
Download speedachieved during the test was - 34.64 Mbps
For your connection, the acceptable range of speedsis 40 Mbps-77.44 Mbps .
Additional Information:
IP Profile for your line is - 77.44 Mbps
Upload Speed
14.45 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 14.45Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
Re: Bad service once again
23-07-2014 2:26 PM
Hi jld51,
Is this result via Wireless or Ethernet? If Wireless, can you please try connected via Ethernet please?
Chris Pettitt
Cloud Environments Engineer
23-07-2014 2:35 PM
Wireless just a shit router you provide...........................
23-07-2014 2:42 PM
Have you tried changing the Wireless Channel?
You can use a router of your own if you prefer.
Chris Pettitt
