Bad pings on forgien servers
- Bad pings on forgien servers
- « Previous
- 1
- 2
- Next »
Re: Bad pings on forgien servers
01-10-2008 4:26 PM
04-10-2008 6:46 PM
My ping on that server i posted is (using cmdprompt) (min/max/avg) 57,58,63 so a hell of a lot better!
and on my new multiplay server i have 18/27/22 so yeah its brill lol
but recently, i dunno where it is this or just the net in general, but 2day my net has been a little bit jumpy, like when i was on cod4, i would disconnect completely for about 10-30secs, and one time i actually came off of vent + xfire, and it happend again about 30mins ago? i dunno whether it is the interleaving, or if its just my dad using the net and not telling me but im gunna give it another chance
04-10-2008 7:07 PM
I was getting a sync rate of 7616 and an IP profile of 7000 which was brill. though of turning off the interleaving to get less latency as interleaving adds 20 to 40ms. but I got then intermittent connection which lowered my IP profile down to 4000 which was shocking lol (having seen 7000kbps)
switched it back on and now rebooting the router every 4 days to get the IP raised back to what it was 6000 kbps so far. I'm not a gamer so bandwidth is more important for me than lower ping time!
your router's error correction and detection plays a massive role in reducing latency and keeping the line steadily On. my router is 2wire from Ebay and its EOL is quite soon I guess lol
05-10-2008 1:13 PM
Quote from: Cobra90 . . . but recently, i dunno where it is this or just the net in general, but 2day my net has been a little bit jumpy, like when i was on cod4, i would disconnect completely for about 10-30secs, and one time i actually came off of vent + xfire, and it happend again about 30mins ago?
With Interleaving off there's no error correction. That means packets can get lost. If too many packets get lost then the BT exchange could resync the connection and if this happens too often you'll end up with a lower speed. What do the router stats show? Has there been a LOS or LOF?
05-10-2008 1:37 PM
Quote from: RamiDoodle I was getting a sync rate of 7616 and an IP profile of 7000 which was brill.
Yep, it would be fantastic if you could because I would want some of it too!
A sync speed of 7616 (which is the max you can get with Interleaving switched on) would only get you an IP profile of 6500. For an IP profile of 7000 you need a minimum syn speed of 7968kbps.
05-10-2008 6:00 PM
06-10-2008 9:53 AM
13-10-2008 4:19 PM
Quote from: MickKi With Interleaving off there's no error correction. That means packets can get lost. If too many packets get lost then the BT exchange could resync the connection and if this happens too often you'll end up with a lower speed. What do the router stats show? Has there been a LOS or LOF?
How do i get my router stats up, and whats LOS/LOF? ima bit of a nooby, but i am tryin to learn
13-10-2008 7:30 PM
13-10-2008 11:15 PM
Quote from: Cobra90 [How do i get my router stats up, and whats LOS/LOF? ima bit of a nooby, but i am tryin to learn
Have a look at this page.
- « Previous
- 1
- 2
- Next »
