Back to terrible speeds.
- Back to terrible speeds.
30-11-2010 8:22 PM
In my opinion BT need a fire lit underneath their backsides and they need to sort out the capacity at the exchange.
Anyway, to the stats:
ADSL Link Downstream Upstream
Connection Speed 8064 kbps 448 kbps
Line Attenuation 22.0 db 13.0 db
Noise Margin 5.6 db 26.0 db
DownStream Connection Speed 8064 kbps
UpStream Connection Speed 448 kbps
VPI 0
VCI 38
I've ran a BT speedtest and confirmed both BT & PlusNet IP profiles match - they do at 6500.
Re: Back to terrible speeds.
01-12-2010 10:04 AM
If you pop your number in here you'll see that the current VP at your exchange is amber, with the following message, "BT is reporting that some of the virtual paths at this exchange are not operating within BT Wholesale's planning guidance, although they are still operating within the product specification.
At busy times, your ADSL connection may operate at a reduced speed, although not all customers on your exchange may be affected. You should only contact support if there is no current ETA date set.
The ETA fix time is: Not provided by BT
Record last updated: 26 Nov 10"
I think that could be the reason, so I'll email them and see what their plans are.
Jojo
01-12-2010 2:19 PM
The exchange going amber actually coincides with the downturn in speeds, the problem is that the area I live in has recently been regenerated after a few years as a large scale building site, the population & thus demand for services has steadily been increassing over the last two years as people return to the area to buy in the new developments. I suspect the exchange hasn't been upgraded much in the last five years, and that the exchange is under a lot of strain, particularly at peak times.
01-12-2010 2:31 PM
I suspect you may be right there. Once i get a reply form the email we might get an idea of what the likely course is, so I'll let you know when I get a reply.
Jojo
02-12-2010 11:01 AM
Had this reply this morning...
[quote=email]Hi Joanne,
The VP for this circuit has been checked and has been found to have breached a trigger threshold instigating congestion relief. A regrade is scheduled, however there are delays published preventing this work. We should have further information when the next report is published on 03/12/2010.
I'll email them for an update after tomorrow.
Jojo
02-12-2010 11:22 AM
06-12-2010 4:44 PM
07-12-2010 11:49 AM
I've now received the email update...
[quote=email]The VP for this circuit has been checked and has been found to have breached a trigger threshold instigating congestion relief. A regrade is scheduled, however there are delays published preventing this work. We should have further information when the next report is published on 10/12/2010
All I can say is that I can check again after the 10th.
Jojo
07-12-2010 4:11 PM
10-12-2010 4:56 PM
13-12-2010 1:09 PM
I've sent an email this morning to ask for an update. I'll let you know when I get a reply.
Jojo
22-12-2010 10:05 AM
22-12-2010 10:22 AM
Thread now split.
22-12-2010 2:07 PM
I've just sent another email. I'll let you know once I get a response.
Jojo
22-12-2010 2:44 PM
