BTW
- BTW
BTW
07-12-2013 8:30 PM
Quote Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
Haven't been able to get additional info from BTW performance tests at all. It was like this when I went on vacation for a month and still broken when I got back couple days back. Anyone know what's going on? It used to work fine.
Message 1 of 5
(835 Views)
4 REPLIES 4
Re: BTW
07-12-2013 9:02 PM
The BT tester has changed over the last year or so, are you using the current tester ?
I just successfully tested my line using this link - http://www.speedtest.btwholesale.com/
Message 2 of 5
(419 Views)
Re: BTW
07-12-2013 9:26 PM
That's what I'm using, still get that
Message 3 of 5
(419 Views)
Re: BTW
11-12-2013 8:04 AM
No-one knows?
Message 4 of 5
(419 Views)
Re: BTW
15-12-2013 12:13 AM
The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.
Message 5 of 5
(419 Views)
