BTW Redirect page
FoolishlyWise
BTW Redirect page
Afternoon guys, Im getting redirected to some sort of redirect page when I tried accessing facebook (before, this was happening when i was trying to connect to google) from BT Wholesale. Anyone know why this is happening? Screenshot of page attached.
Cheers
houlton23
Re: BTW Redirect page
Assuming this only happens on Facebook, This is probably left over from the maintenance last night and I would suggest you should clear your DNS and Browser Cache to clear the problem.
Start -> Run -> cmd -> ipconfig /flushdns
Then restart your browser, and computer too if just the browser doesn't fix it.
Alex Smiley
penguin
Actually I've been having a similar issue. It seems to affect only certain websites. Often the way to clear it is to reset the router (resetting the sync with the exchange).
This happened a lot when we first joined PN, but it hasn't happened for a while. Then last week it came back with a vengeance. Any ideas on what might be causing this? (Flushing the DNS doesn't seem to have resolved the problem).
FoolishlyWise
Quote from: houlton23
Alex Smiley
You are a legend. Thank you so much!
@Penguin, Have you tried reporting it as a fault? Could be BTW not liking your IP address, so the resync sorting that.
Oxslow
keep on gettting redirected to here http://62.6.38.125/index.html
Ever since the down time last week intermittently I keep on getting redirected here http://62.6.38.125/index.html Where it says about BT Wholesale having trouble connecting to my ISP. Do I need to raise a ticket and is anybody else still having problems?
Fixes: 131
Have a read above.
Customer and Forum Moderator.
penguin
It went away for a couple of days but it's happening now again. I think I'll file a fault and see what PN say.
It got so bad at one point that I couldn't even load the PN Usertool to identify which gateway we are connected to! Thank goodness I can VPN in to Uni!
Gosh a minute ago it was so poor I couldn't event VPN in- this is bad!
grhm
Yes, having the same problems here - been happening on and off for a week - resynched don't know how many times but keeps coming back.
Oxslow
When I try this it does work but it is only a temp fix.
I think I am going to have to post a ticket.
Oxslow
Great I can't even raise a ticket. The broadband fault checker is not working and it tells me to contact the support team.
jojopillo
Hi guys,
I'd suggest setting your DNS in the router manually, this has resolved that issue before.
Jojo Smiley
Oxslow
Are these the right ones?
212.159.13.49
212.159.13.50
jojopillo
Yes,
Or you can use
212.159.6.9
212.159.6.10
Smiley
Oxslow
I will stick to the ones I am using as that has fixed the problem for me. Thanks Jojo.
penguin
Yes my support ticket got updated saying to point to PN's DNS servers. It seems to have been behaving itself so far. Fingers crossed!
Ps I love how it's blamed on BT's OR modem and BT's DNS server !  Tongue
