BT wholesale speed test
- BT wholesale speed test
28-10-2016 6:03 PM
Hi for months now when I run the speed test and try to go to further test for IP profile all I get is "
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
Re: BT wholesale speed test
28-10-2016 9:06 PM - edited 28-10-2016 9:07 PM
I get the same, but was able to get my line profile from here.
Enter your full ADSL telephone number and click the Check button.
29-10-2016 8:05 AM
Thanks for that I'll give it a go
10-11-2016 11:28 PM
well gave it a go and that site doesn't work in appears there's no way to get the info
11-11-2016 1:11 PM
Your profile is currently at 3000. Let me know if there's any more info you'd like.
11-11-2016 8:15 PM
Thanks for that I thought it should be at 3 but always get speed test of 2.37 which is strange ?
21-11-2016 12:53 PM - edited 21-11-2016 12:55 PM
Great news wholesale speed tester has started working again and after 4 days of been synced at 4000 my IP profile is 3.5 BUT speed test is just 2.88 ? so why doesn't it just kick in like it did with my previous provider ? ( which is looking like getting me back at this rate )
21-11-2016 11:34 PM
Working here for me as well.
The thing you need to be looking at is your Plusnet Current Line Speed. If that is significantly lower than the BT IP Profile, it needs a nudge, Staff on the forums will usually do that for you.
22-11-2016 6:53 AM
cheers that says 3.5 but speed test is still at 2.8 , I know its not much but when your speeds are this low every bit counts plus I still pay the same as every one thats getting usable speeds + to even get this I've had to buy quite a few routers
