BT to sell self fit bell wire filter.
- BT to sell self fit bell wire filter.
03-07-2008 7:47 AM
PC Pro magazine has a news item that states BT is supplying a self fit bell wire filter.
http://www.pcpro.co.uk/news/news/177375/
http://www.pcpro.co.uk/news/209976/bts-broadbandboosting-iplate-goes-on-sale.html
Re: BT to sell self fit bell wire filter.
03-07-2008 7:55 AM
Quote News
[Internet]
Wednesday 12th March 2008
and has been fully covered in previous threads
04-07-2008 7:45 AM
Could you point me to threads that cover this explictly.
Has anybody been able to buy an iPlate in their local DIY shop like Homebase, B&Q or Maplins yet?
The iplate seems to be an inline filter that requires NO wiring modifications.
It seems to only require unscrewing the NTE5 faceplate and plugging in the iPlate then plugging in the original faceplate with home extension wiring attached!
I googled iPlate and there are loads of hits, as you suggest.
http://www.hmmm.ip3.co.uk/iplate.shtml
The Openreach NTE5A master socket I blagged off the BT Openreach van has an extra inductor to filer the bell wire.
Has anybody been able to buy an iPlate in their local DIY shop like Homebase, B&Q or Maplins yet.
My local hardware store were selling the 4 wire micro filters and 4 wire telephone extension.
Although round, the extension wiring had no twisted pairs to reduce interference picked up on a long run.
Doug
04-07-2008 8:03 AM
Then went back to Google and looked for the Community items found this
http://community.plus.net/forum/index.php?topic=62179.msg502579
04-07-2008 8:06 AM
05-07-2008 7:17 AM
The thread mentioned above is very helpful. P Richardson's contribution especially.
It is still worth reading paragraph 7.3 in the BT SIN 346 suppliers information note.
( http://www.sinet.bt.com/346v2p6.pdf )
05-07-2008 9:38 AM
SIN346 (now at v2p7 by the way, not that para.7.3 changed) doesn't apply to the i-plate as I understand it. The i-plate is just a self fit bell wire filter for those that don't want to disconnect their bell wire or fiddle with their wiring. Whether it gives the same performance (same comment to the new SSFP from OpenReach) as a disconnected bell wire or fully filtered face plate in this respect is another question.
05-07-2008 12:33 PM
Oh dear, you are right!
I have confused Line Port and Line Box.
Is the Line Box is the master socket?
Is the Line port is the plug of the CPE filter?
Anyway disconnecting the bell wire DOES reduce interference, and improve performance.
My experiment where I connected my extension wiring via my Solwise microfilter was my "breakthrough" measurement.
I plugged the microfilter into the NTE5 test socket, and then the NTE5 faceplate and extension wiring into the telephony port. My downstream speed jumped from 3776 to 5248 kbps
See http://www.dougrice.plus.com/Erlangs/adsl_Appendix.htm#l20
05-07-2008 12:41 PM
05-07-2008 12:45 PM
When I was trying to improve my line stability I compared the results from the test socket to the normal master socket with and without the bell wire to the extensions being connected. There was a clear improvement when comparing the test socket to the master socket with the bell wire connected but no change with the bell wire disconnected.
I then tried the same test with an ADSLNation filtered faceplate and having the bell wire connected or not made no difference.
05-07-2008 1:29 PM
