BT to Plusnet
- BT to Plusnet
BT to Plusnet
21-03-2010 7:05 PM
sent in mac code now i have been checking what has been going on its saying on order tracking that there is a problem with the line, it said this last night but the internet worked today i try it and my internet has stopped i didnt think they would have people working on sundays now i have to use my iphone with no wi fi ,
my home hub can i use this for plus.net? i said no to the one that was offered wired with no wifi or the wireless where i have to put a network card in my computer to connect, so yes if i can use my home hub how?
do i need to download any software?
how long does it usually take to sort the line out?
thanks
thanks
Message 1 of 4
(1,047 Views)
3 REPLIES 3
Re: BT to Plusnet
21-03-2010 7:13 PM
Have you tried putting the Plusnet username etc in your router
Message 2 of 4
(475 Views)
Re: BT to Plusnet
21-03-2010 7:49 PM
yeah ive tried putting it into the homehub page and in window both to no avail in the home hub it says authentication fail,the home hubs internet button is just flashing yellow
Message 3 of 4
(475 Views)
Re: BT to Plusnet
21-03-2010 8:11 PM
Hi there
Most BT Home Hubs, that I know of, are locked to BT Retails network. Some, depending on the model number, can be unlocked. Further info here http://en.wikipedia.org/wiki/BT_Home_Hub
I have no idea how BT view this or whether it breaches any T&C's with BT Retail so best to check prior to doing anything, or if not, do so at your own risk.
Failing that we could get one of our routers sent out if needed.
Mark
Mark
Message 4 of 4
(475 Views)
