BT speedtester up the creek again?
Fixes: 18
I have been trying to use the BT speedtester for the past half hour, and I keep getting all sorts of "usual" error notices  "exception notice"  "wrong user name"  etc.,
yet the thing still says "No known problems"
any one else had any luck lately with this infernal testing device?
pierre_pierre
Re: BT speedtester up the creek again?
I should think its for the same reason as the portal problem, speed tester cant access that either
Fixes: 18
Have no problem with this    http://www.mybroadbandspeed.co.uk/
have accessed it at 08:07, 11;00, and just now 12:06  all o.k
jut had another go at BT and still same  "exception error"  Undecided
pierre_pierre
But mybroadband doesnt ask you for your login, BT does
Fixes: 18
Sorry Pierre, I thought that was what you meant by... "speed tester cant access that either"
Never mind, will just have to keep trying.... did not know the two systems were linked (P/N portal, and BT speedtester)
pierre_pierre
I am just guessing as you have to enter you user ID
