BT speedtest broken again
rongtw
Fixes: 12
the past couple of days i havent been able to do a speedtest  Shocked i keep getting a "error has occured "
is it just me or has it gone down again ?
Re: BT speedtest broken again
Its you  Cheesy
It works for me
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
32110
Not working here. Get the following message:
Test Error
The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.
Embarrassed
Fixes: 61
same for me
maximod
Shows Test error here also.
Fixes: 51
Yep it's broken again Sad
Customer and Forum Moderator.
Stumpy21
Hi
Still working OK for me!
Derek
kevanne7
Working OK in bolton ; ;
Fixes: 51
Not all customers were affected last time it was broken. You must be some of the lucky ones. Smiley
now I'm getting the infamous error raise the issue with your provider  Sad
Fixes: 46
The BT tester just worked for me though I got "test error"  from several tries last night. Roll eyes
David
It just worked for me (Dowload test) but:
Note: An Upstream test was not conducted on this line due to a technical issue. If your concern is related to upstream performance then please retry
the performance test again in 1 hours time.
Call me 'w23'
Fixes: 51
I've now just managed to do a fully successful test.
rongtw
Fixes: 12
Cheesy it worked for me this mornin, they must have sorted it  Wink
