BT speed tester.... what use is it?
Fixes: 13
I have done the BT speedtest three or four times in the last 24 hours....
Apart from the rediculously long time it takes for the main page to load, before even starting the test.... (up to 6 minutes) after a re-start because of "not responding" for 10 minutes.
When you get a result like this....
Test1 comprises of Best Effort Test:  -provides background information.
Download  Speed
                                   824 Kbps
0 Kbps------------------------------------------------ 2000 Kbps
        .Max Achievable Speed
Download speedachieved during the test was - 824 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Additional Information:
Your DSL Connection Rate :0 Kbps(DOWN-STREAM), 0 Kbps(UP-STREAM)
IP Profile for your line is - 1250 Kbps
When using other speed testers, immediately after give the following information....
www.speed.io
Downstream  1170    Upstream 372     Connections/minute = 1600    ping   46 ms          (equivalent to 1300kbps) or 1.3 meg
My broadband speed
Downstream 1180  Upstream 367
www.speedtest.net
Downstream   1160  Upstream  380   ping 48 ms
So according to our "most important" speed test.... and the only one that PlusNet and BT consider "good enough" for fault tracing.....
I have actually achieved the impossible,  I have attained a speed of 824 k on a line that has NO traffic Downstream and NO traffic Upstream.... BT speed tester reports that is the "Best Effort"..... well, I don`t really know which way to take that ...
Any comment from our  PlusNet staff on why BT (and of course Plusnet)  use such a useless piece of software to convince us we are getting their "best effort" ? ? ?
Fixes: 13
Re: BT speed tester.... what use is it?
Obviously not  Sad
Fixes: 32
Hi shutter,
There are some known issues with the BT speedtester, I'll make sure you are kept informed BT's progress with regards to a fix.
 Adam Walker
Fixes: 13
Yay !.... I wonder how long it will take for them to do a FIX so that it doesn`t take so long to load up the page, and also that it compares better with the other speedtesters...
I seem to remember there has been "issues" with it, for the past 3 years , since I first got onto PlusNet, and had to use the BT speedtester... it has always been a bit of "chance your arm" if it worked properly... and not a very good "advert" for BT technical/software department.....
I suppose BT need your phone number to "tie in" with their faulty line department.... but it makes you wonder when other speed test providers do not require your phone number before starting a test... why does BT ?
Plusnet Staff
Plusnet Staff
Fixes: 159
That's because other speedtesters don't allow the support staff to grab the results, nor do they give the IP profile or current connection rates. Smiley
 Chris Parr
 Plusnet Staff
Fixes: 13
But ... there again.... BT does not provide "ping" times.... nor does the "mybroadband" ..... most other speed testes do provide ping times. and also show the "throughput" figure.... altogether the "rival" speedtesters give the customer a much better User Interface.... and quicker service from start to finish...
. BT could learn a lot from them.... (and still need the phone number if they want to ! ! ! ! )
Fixes: 13
OK... Here we are again.... done my 3 days waiting for BT to upgrade my profile from 1250, to the next level,... and then I do another BT speed test with the same USELESS result....
How they manage to "fault find" with such a rubbish piece of software beggars belief....You would think that they would FIX things like this..... (wouldn`t you? ? ?)
Download  Speed
783 Kbps
0 Kbps__________________________________ 2000 Kbps
Download speedachieved during the test was - 783 Kbps
Your DSL Connection Rate [font=Verdana][font=Verdana]:0 Kbps(DOWN-STREAM), 0 Kbps(UP-STREAM)
My routerstats show a virtual flat line since 1200 (when I started to use it)... a sych rate of 1760  and an SNR of 5.8 (now 5.5) NO spikes.... NO  disconnections.... NO interference...
from that you would expect.... NO EXCUSES from BT for such a lousy speed...
Fixes: 32
shutter,
I've just been discussing your slow speed issue with Chris, I can see you've raised a fault so we need to let the CSC and fault teams do their stuff for the time being. Please do give me a shout if you encounter any problems getting this dealt with.
Adam.
 Adam Walker
Fixes: 13
Thanks Adam...
Will go and update the ticket with this morinings speed test results, to compare with BT pathetic speed tester result...!  Undecided
EDIT EDIT EDIT
just done another BT speedtester...... took over 9 minutes to get to the actual test from the initial start page.. (waiting for the logo to appear)..... Undecided
throghput speed    1250
BEST EFFORT (ha ha ha)
actual speed ......... 924k
max speed 2000 k  (ha ha ha)
DSL Downstream... ZERO  upstream ZERO  (boo hoo  boo hoo boo hoo)...
your profile is 1250.... (correction .... your profile is absolutely anyones guess, cos the BT speedtester isn`t reliable  or working properly)
Fixes: 32
Shutter,
To avoid unnecessary frustrations I would advise leaving the BT speedtester alone until we know for definite that it's doing what it should be Smiley
Adam
 Adam Walker
Fixes: 13
Thank you, Adam, for those words of encouragement ! ! ! ......
at least PlusNet are now admitting the BT speedtester is a load of CATFISH  Cheesy
and possibly have advised BT to do something about it P.D.Q.  Wink
Fixes: 32
But catfish are awesome creatures!
The BT tester is very useful for us when it's working, rest assured we are pushing for a fix.
 Adam Walker
