BT speed test. A new low
- BT speed test. A new low
23-02-2009 10:41 PM
had to post this. Just checking if my bt ip profile had increased yet and the throughput result made me laugh
Your DSL connection rate: 3840 kbps(DOWN-STREAM), 832 kbps(UP-STREAM)
IP profile for your line is - 2500 kbps
Actual IP throughput achieved during the test was - 21 kbps
Dont panic mr Mannering speedtest.net came back as normal.
bt speed test really hates my line but never had a 2 figure result before
Message 1 of 5
(1,023 Views)
4 REPLIES 4
Re: bt speed test a new low
23-02-2009 10:46 PM
If and when it works, the BT Speedtest is fine for checking IP Profile, but I've found of late that it's impossible to have any confidence in the throughput figure.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Message 2 of 5
(448 Views)
Re: BT speed test. A new low
23-02-2009 10:49 PM
Message 3 of 5
(448 Views)
23-02-2009 10:54 PM
This is the official BT speedchecker:
http://www.speedtester.bt.com/
Message 4 of 5
(448 Views)
23-02-2009 11:06 PM
on speedtest.net in my town stats plusnet is the 2nd best upload
dont worry euge when you get that i-plate and sort your line out you will boost plusnets speed results in your town
Message 5 of 5
(448 Views)
