BT speed checker estimate wrong - assume i can disregard the estimate
- Re: BT speed checker estimate wrong - assume i can...
18-01-2013 1:31 PM
After been away for 3 yrs I am thinking of moving my line and bb back to PN
The BT speed checker gives an estimate of 3.5mb , i assume this info is out of date, as i sync at the full 8128kbps.
Am i correct in thinking if i switch ( 20CN exchange ) i will still sync at the full 8128kbps and can disregard the BT estimate.?
Kind Regards
Mike
Kind Regards
Mike
Message 1 of 3
(846 Views)
2 REPLIES 2
Re: BT speed checker estimate wrong - assume i can disregard the estimate
18-01-2013 1:32 PM
Hi Mike,
Assuming that your service is currently 20CN, there is no reason why you speeds should drop from what you currently experience.
Message 2 of 3
(389 Views)
18-01-2013 1:37 PM
Hi James
Thanks for your response, will go ahead and place my order.
Kind Regards
Mike
Kind Regards
Mike
Message 3 of 3
(389 Views)
