BT profile 7150 - PN profile 6500 after 5 days
Tony_W
Not that I am really complaining - 6500 Kbps has, up to now, been the best that PN or BT have provided.
However, now I'm on 21CN and the BT profile has gone up to 7131 Kbps. The higher BT profile has been in place since at least last Wednesday and has not been matched by a change in the PN profile .
Should I expect them to match?
If I got another router - I'm using a borrowed Siemens Gigaset SE587 synching at  7616 Kbps - could I expect faster synching speeds from a 21CN connection?
Current BT speedtest gives....
Download speedachieved during the test was - 6346 Kbps
For your connection, the acceptable range of speedsis 1000-7150 Kbps.
Additional Information:
Your DSL Connection Rate :7616 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 7131 Kbps
Tony
WebDude
Re: BT profile 7150 - PN profile 6500 after 5 days
Quote from: Tony
Jojo manually prodded the PN system the other day for someone, where profile had not changed.  See if someone in PN Towers spots the thread in the morning, or consider ringing and speaking to someone (don't know if broadband faults people work all night, or just up to midnight, so maybe chat with someone tonight if poss?)  It may be a tiny proportion where the BT and PN systems aren't "in sync" but clearly if it's your line, you notice...  Good luck if you do get some other router ... somewhere there's a table showing the data transfer speeds for various bands of exchange sync speeds, so you, if you can reliably stay connected at a higher speed to the exchange, you should see (eventually, or via prodding PN) a throughput increase.
Tony_W
Thanks for the information WebDude. I will take your advice and hope that this is picked up by someone from PN.
Will this come under the new facility outlined in the '21CN SNR resets' topic?
Tony
jojopillo
Hi Tony W,
just ran a line check
Downstream Link Info
Speed
        7616
Downstream BIP Interface Data
Current Line Rate
        6500
Firstly, although you are on 21CN you are on ADSL1 so your maximum would be 8128 (which would give you a profile of 7150) your rate of 7616 is the maximum for a line with interleaving on so your profile is 6500, just what we would expect. I've no idea why the speed test gave 7131 as there is no such profile, but I can assure you, as the test I have just run on the BT system, it is currently 6500.
Jojo Smiley
Tony_W
Something is a bit fishy as I have just re-done the BT Speed test and it is now giving:
Download speedachieved during the test was - 6223 Kbps
Your DSL Connection Rate :7623 Kbps(DOWN-STREAM), 1169 Kbps(UP-STREAM)
IP Profile for your line is - 6500 Kbps
An upstream rate of 1169 Kbps?
The downstream is also an odd amount.
The IP Profile has returned to 6500 even though it was up above 7100 in the two previous measurements 5 days apart.
mybroadbandspeed.co.uk gives:
Today 11:35 5575 kbps (697kB/s) 369 kbps (46.1kB/s)
Which looks more realistic.
Tony
jojopillo
Hi Tony W,
have you thought about maybe going on to ADSL2+ ?
Jojo Smiley
Tony_W
Hi Jojo,
I am a business user and I do not think that it is an option.
I understand that it might also involve obtaining a different modem/router, but I have not investigated it.
Tony
jojopillo
Hi Tony,
Yes, you are quite right, I was too busy checking your stats to notice your package.
Jojo Smiley
Tony_W
Hi Jojo,
Seems a little unfair given the cost of business packages.
What are the chances of the restriction being lifted soon?
Tony
WebDude
Quote from: Tony
Think I saw a comment about BT speed test being a bit odd at present - doing some changes or something...
jojopillo
Hi Tony,
You can have ADSL2+. the reason we don't do it for business is that there is a higher fault rate on longer lines and as you will appreciate there is much more impact to a business that loses connection than to a residential line. You seem to have a good connection though, so up to you really!
Jojo Smiley
Tony_W
Hi Jojo,
I am fairly close to the exchange:
Distance:- Direct:    978 metres
 (appx)* By Road: 1.29 km
Estimated speed 21CN WBC : 13000 kbps  (13 Mb)
so I might be a stable candidate.
How do I go about requesting the move to ADSL2+? Do I raise a ticket?
Tony
jojopillo
HI Tony,
Just had a word with one of our biz guys and he said yeah, just raise a ticket. He did warn that faults can take longer to fix, so that's another reason we don't normally offer it to biz customers.
Jojo Smiley
Tony_W
Hi Jojo,
Thanks for checking. I am hoping that it does not involve a BT guy with a torch, climbing gear and a soldering iron visiting the exchange Wink
I had already raised a ticket (number 3517556Cool about 90 minutes ago and am awaiting a reply. The ticket system says to expect a delay of over 6 hours for a reply to any new ticket.
Thanks again,
Tony
jojopillo
I think they use those hard hats with the built in lights theses days Tony Wink
