BT line checker
- Re: BT line checker
BT line checker
21-06-2009 8:56 AM
Hi
Just noticed something - wondering if any one else has noticed it or can check.
I'm on 21CN now and having problems - speed is much slower now. Since this change I've spotted that the BT checker as downgraded the estimated speed I can get.
In the ADSLmax days estimate was 4mb - was getting 5.5mb.
Then I moved to the LLU product (6.5 to 7.2mb) - and now back on BT 21CN where the estimate is now 3mb and getting (at the moment) 3.5mb. (was down to 2.5mb).
Has anyone else noticed this?
Phil
Phil
Message 1 of 3
(1,251 Views)
2 REPLIES 2
Re: BT line checker
21-06-2009 11:31 AM
For me it reports speeds that are in line with what I have experienced.
ADSL up to 2Mbps
ADSL max 5.5Mbps
ADSL2+ 8Mbps or greater
ADSL up to 2Mbps
ADSL max 5.5Mbps
Message 2 of 3
(414 Views)
Re: BT line checker
21-06-2009 11:39 AM
Out of interest - I am not on the trial - I checked my results
Actual totally stable sync is just under 4Mbps
The interesting bit about this is the first line because under the old attenuation rules I could only get 1Mbps
Quote Your exchange is ADSL enabled, and our initial test on your line indicates that your line should be able to have an ADSL broadband service that provides a fixed line rate up to 2Mbps.
Our test also indicates that your line currently supports a potential ADSL Max broadband line rate of 2.5Mbps or greater.
Your exchange is planned to have ADSL2+ by 28th February 2010. Our test also indicates that your line currently supports a potential ADSL2+ broadband line rate of 2.5Mbps or greater.
Message 3 of 3
(414 Views)
