BT hub 4 and HP wireless printer
NorthEasterner
Would anyone know about this that I have posted over BT forums?
http://community.bt.com/t5/Other-BB-Queries/BT-hub-4-and-HP-wireless-printer/td-p/893368
Ex Plusnet Fibre customer. BT Infinity Customer using a BT Smart Hub. If you wish to say thanks, please click the thumbs up Thumbs Up
1 REPLY
Fixes: 16
Re: BT hub 4 and HP wireless printer
Devices on the 2.4 GHz band should be able to communicate with devices on the 5 GHz much the same as how they can also connect to devices plugged into the wired ethernet ports.
