BT have sorted my wiring - can my BRAS profile be increased.
- BT have sorted my wiring - can my BRAS profile be ...
16-01-2010 10:41 AM
Until last year I had a bombproof 8mb/s connection. Then I started getting speed problems, and noise on the phone line. The intermittent nature of the fault means it has taken until now to get BT Out to fix the line.
A very nice man has just been, and re-wired the junction box at entry to the house, and fitted a new Openreach master socket for me. I fully expect this will give me back my stable connection.
1 - Can plusnet now reset my target SNR, (I am currently connected at 8128 with 15.6db noise margin
2 - Can plusnet now reset my BRAS profile so it can go back to max.
3 - Am I correctly informed that the new openreach master socket has the I-Plate functionality built in?
Thanks.
Thanks.
Message 1 of 7
(1,796 Views)
6 REPLIES 6
Re: BT have sorted my wiring - can my BRAS profile be increased.
16-01-2010 10:49 AM
8128 is the maximum you can synch at, so nothing to do there
Your BRAS will raise itself on the BT side, you need to check what speedtester.bt.com says.
Message 2 of 7
(689 Views)
16-01-2010 10:57 AM
BT Speetester says:
My broadband speed (Plusnet speed profile) is 5500 - so it looks like plusnet need to catch up with BT.
Quote Download speedachieved during the test was - 4533 Kbps
Additional Information:
Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 7150 Kbps
Message 3 of 7
(689 Views)
16-01-2010 11:01 AM
Looks like it's all going well - it can take the automatic Plusnet system up to 12 hours to catch up with IP Profile changes.
I'm just a touch surprised at a speed of 4533 when the portal is set to 5500 as it's a little bit lower than I would have expected. Are you connected wired or wireless to the router? Have you optimised your MTU and RWIN settings?
Message 4 of 7
(689 Views)
16-01-2010 11:39 AM
My experience is it takes much longer than 12 hours for plusnet to catch up.
Message 5 of 7
(689 Views)
18-01-2010 9:59 AM
Your profile on our side increased over the weekend, so it's up to date now.
Don't worry about the SNR, that's just high because your line is good quality, as your syncing at 8128 it's not causing any issues.
Message 6 of 7
(689 Views)
18-01-2010 7:03 PM
Thanks - all is looking good.
I may try my old router again now. When all the problems started, I put it down to that, and got a new one.
Message 7 of 7
(689 Views)
