BT business smart and 4g assure
Greg1984
Hi
I'm just thinking to get one BT business smart and 4g assure,can someone tell me if this will work with plusnet?
I did some research but I cannot find anything about 4g assure.
I will really appreciate for any help
7 REPLIES 7
Fixes: 526
Re: BT business smart and 4g assure
The Business smart hub can be used with PlusNet.
The 4g assure will only work with BT retail broadband.
Greg1984
Thank you for your support 🙂
Greg1984
Hi
Sorry to bother you again but I got one more question
Bt smart hub 2 with hybrid construction will work with plusnet?
I will appreciate for your advice
Fixes: 526
Im not sure what you mean by hybrid construction ?
Please explain
Greg1984
Hi
Sorry should be hybrid connect
Bt business smart hub 2 with hybrid connect
RealAleMadrid
Fixes: 66
@Greg1984 Hybrid Connect is a 4G device that uses the EE mobile network. It will not work with Plusnet Broadband.
Fixes: 457
@Greg1984
You can call it hybrid connect, 4g assure or whatever but from my reading it is nothing but a Smarthub plus a plug in mobile dongle.
As @MisterW  stated at the beginning of this thread, the Smarthub can be set to work on a Plusnet account but the mobile fallback dongle will not do anything and should not be connected.
