BT WiFi
- BT WiFi
BT WiFi
05-04-2014 7:24 PM
Hi All
Just a quick question is it correct we get BT WiFi at the hot spots for Free.
If so what is the procedure for getting connected please?
Thanks..Osh
Thanks..Osh
Message 1 of 2
(566 Views)
1 REPLY 1
Re: BT WiFi
05-04-2014 7:53 PM
No you don't you have to be a BT member to get that for free, Plusnet while owned by BT operates as a separate company same as it was with my Previous ISP BE who were owned by O2 now sadly Sky, basically if you want to use a BT wi-fi hotspot your going to have to pay for it.
Message 2 of 2
(260 Views)
