BT Wholesale Checker - Does it check for presence of DACS?
CX
We have previously checked for broadband availability on a particular phone number, which has come back with the result that the line has a DACS device on it and so cannot accomodate broadband.
The last time we checked was a couple of years ago.
Checking the BT Wholesale Checker now, and there are no issues reported, with both ADSL2+ and FTTC being available. But does the BT Wholesale Checker have this information in its database?
Fixes: 10
Re: BT Wholesale Checker - Does it check for presence of DACS?
I believe it still does. However even if it has DACS you should still be able to order broadband and OpenReach will remove it.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
It is something that should show up as far as I'm aware, as jelv mentions though it's something that would be able to get sorted anyway.
