BT Wholesale Broadband Performance Test - irractic readings
LindaB0
BB speed usually 20 download, 1.04 upload however as BB has been extremely slow all morning, speedchecks of less than 3 download, 0.3 upload, I did several of the above tests. Initail reading of 20.67 down, 1.04 up, ping 29.25.
HOWEVER on immediately retesting I confirmed the results of 2.86 down, 0.45 up, 00 ping?
Whats happening. Now checked 3 - 4 times with same results. won't let me do a diagnostics, states error try later! tested 1415hrs, 1416hrs today
7 REPLIES 7
MatthewWheeler
Fixes: 479
Re: BT Wholesale Broadband Performance Test - irractic readings
Were those tests done over a wired or wireless connection?
 Matthew Wheeler
LindaB0
wired.
also done quiet line test which is 'quiet'
MatthewWheeler
Fixes: 479
I've made some remote changes which should help.
Can you retest it in the next 15 minutes?
 Matthew Wheeler
LindaB0
will do. Thank you so much. fingers crossed.
LindaB0
Ah! all is well. Joy to the power of the 'tweak'.
Thankyou for your time, it is really appreciated.
MatthewWheeler
Fixes: 479
Glad to hear it.
 Matthew Wheeler
Mav
Fixes: 515
Moderator's note by Mike (Mav): I have changed the fix to MatthewWheeler as per message #4
Forum Moderator and Customer
