BT Wholesale Broadband Performance Test FTTC
- Re: BT Wholesale Broadband Performance Test FTTC
27-02-2014 1:27 AM
I just get back to you as it now 27th February as you did metioned to me last post. As my BT Wholesale Broadband Performance Test with further diagnostics with my phone number never work since FTTC was installed on 13th February. But, I had a second thought, why not try ping test via speedtest.btwholesale.com and it came back with timed out. Not sure if this caused this or at BT's end.
I will awaiting from you later today to get it sorted out. Thanks Chris.
P.S.
Have anyone else had a problem running ping test www.speedtest.btwholesale.com?
27-02-2014 3:34 AM
27-02-2014 9:44 AM
I'll raise a case with our suppliers on this. Can you add further screenshots (which include the time and date displayed in the bottom right hand corner of your screen) so that I can pass this over to our suppliers.
27-02-2014 9:52 AM
27-02-2014 10:15 AM
Quote from: goldenfibre Have anyone else had a problem running ping test www.speedtest.btwholesale.com?
Only a very poor upload speed & high pings
27-02-2014 10:31 AM
27-02-2014 10:32 AM
On a call with them at 11am.
27-02-2014 10:38 AM
27-02-2014 10:40 AM
27-02-2014 10:52 AM
27-02-2014 11:02 AM
27-02-2014 11:59 AM
27-02-2014 12:01 PM
27-02-2014 12:08 PM
I'll use this thread to keep regular updates on as it's easier for everything to all be in once place.
I've had a chat with the Helpdesk and also with a bunch of developers who work with PT (Performance Tester). I would like to make it absolutely clear with regards to the PT;
There are no server-side capacity issues with the website itself - there is more than enough room for many, many users to run speed tests simultaneously.
There is an issue with a piece of equipment called SAM. SAM is element manager equipment and gives profile updates and determines faults, this is being overloaded, it affects all 21CN (ADSL, ADSL2+, FTTC and FTTP) products. When this becomes overloaded, you'll be presented with an error message asking you to try again later. Unfortunately this is pretty much the only error message you can receive as the website has difficulties in determining what type of problem you might be having and therefore spits that error message out.
The SAM Issue has been ongoing and hasn't been communicated out as effectively as we'd have liked, however, we are now aware if the issue and I will be getting regular updates on this - to which I can provide updates on this thread. There's no ETA on this at the moment, but as soon as I get more information, I'll update you all.
TAP3 Issue
Not a lot to say on this just yet, other than the fact, I'm going to run an investigation as to what me causing this issue. I'll provide more information as and when I have completed some testing.
goldenfibre
I've brought your case up specifically with the ASG Team (Who deal with such cases). They've found a problem with the Downstream interface (UII) inventory system which didn't return a proper response which is why it's just thrown an error page up.
I've got one of the Developers working on this now, and they are just checking what work needs to be carried out to resolve this issue. I'll update you as and when I get more information on that for you.
Any questions, do shout up, and I'll do my best to answer any questions you might have.
27-02-2014 12:12 PM
