BT Speedtester
BT Speedtester
At least once a week I run the BT speed-tester, but today it doesn't recognise my network details.
Test Error
Performance Tester was not able to find all the network details required for telephone number:01nnnnnnnnn. Please check that it is the correct telephone number for your service, and ensure that the PC you are using to run the speed test is connected to your broadband connection. Try again and if the problem persists then please contact your service provider.
My IP address is currently 87.112.nnn.n which is definitely in the PlusNet IP pool.
Anyone else having issues?
JayG
Re: BT Speedtester
Just tried it - worked OK (IP address 87.112.***.***)
Re: BT Speedtester
Must have been a temporary glitch - working again now.  Smiley
Fixes: 55
Re: BT Speedtester
I think BT were updating the performance tester over the weekend to cope with the higher speed FTTC profiles. Perhaps all has not gone to plan.
However it is working for me (IP totally different from those).
David
David
