BT Speedtester
- BT Speedtester
BT Speedtester
18-05-2009 9:45 AM
During a severe slowdown episode I've used (tried to) the BT speed tester as well as the Ookla on the PlusNet site. The Ookla seems consistent . Its reported speeds generally match the real-live experience. And it completes its test in short order.
The BT tester only works for me once in 10 or 12 tries. Last night it completed a test with good looking speeds in 10 minutes or so. Today (at 08:02) again I have waited for one hour for it to complete before giving up and sending off this query. I have on occasion waited two hours with no completion.
90% of attempts to use the BT tester result in long waits and no completion. For evening attempts this may be understandable, but I try morning, afternoon and evening with the same result/non-result.
Is that normal?
Is that normal?
Message 1 of 4
(804 Views)
3 REPLIES 3
Re: BT Speedtester
18-05-2009 9:47 AM
Hiya,
You wouldn't be the first person to experience difficulties with the BT Speedtester.
I'm afraid that at times it can be notoriously troublesome.
Message 2 of 4
(293 Views)
Re: BT Speedtester
18-05-2009 3:12 PM
OK. So situation normal. Thanks.
Message 3 of 4
(293 Views)
Re: BT Speedtester
18-05-2009 8:43 PM
You need Java Runtime Environment (JRE) installed for the BT speedtester mind (just in case you didn't know).
Message 4 of 4
(293 Views)
