BT Speedtester.
- BT Speedtester.
BT Speedtester.
30-03-2008 9:17 AM
I have now been trying to use it for seven days, trying several times each day. Every time I run it, it won't run, and gives me the error message:
The system is currently busy. Please try again shortly.
So, for the past week, I've not been able to test my speed using the 'official' tester.
Has anyone managed to use it, or does everyone get the same message each time?
Is there an acceptable alternative for me to try?
Many thanks
Keith
Re: BT Speedtester.
30-03-2008 9:24 AM
Re: BT Speedtester.
30-03-2008 9:52 AM
Re: BT Speedtester.
30-03-2008 10:05 AM
Re: BT Speedtester.
30-03-2008 10:17 AM
Quote from: pierre_pierre no the one you are supposed to use is the BT speed tester www.speedtester.bt.com
Yes, i was referring to the BT speedtester. just tried it again - no joy
Re: BT Speedtester.
30-03-2008 10:53 AM
Just tried it again and it's not working.
Keith
Re: BT Speedtester.
30-03-2008 11:23 AM
IP profile for your line is - 7150 kbps
DSL connection rate: 448 kbps(UP-STREAM) 8128 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 6334 kbps
Re: BT Speedtester.
30-03-2008 1:34 PM
Regards .....
Re: BT Speedtester.
30-03-2008 1:50 PM
Chilly
Re: BT Speedtester.
30-03-2008 2:11 PM
I think a number of ISPs rely on this tester. Maybe it's too overloaded.
Re: BT Speedtester.
30-03-2008 2:21 PM
IP Profile - PlusNet have access to that
Connection rate (sync speeds) - most people can, with a little help, find that from their router/modem
Throughput - loads of places to test at and PlusNet have their own favourite of course at http://www.mybroadbandspeed.co.uk/ ;
Re: BT Speedtester.
30-03-2008 2:28 PM
From memory I think there is one piece of info that only the BT tester supplies and this is why PN always ask for it if anyone has a speed query.
Re: BT Speedtester.
30-03-2008 2:35 PM
PlusNet - what are you doing to "rattle BT's cage" on this one?
Incidentally, the "retry interval" was 30 minutes until quite recently and it's not so long ago that there was no restriction.
My own suspicion is that it's being used much more due to unsatisfactory performance for 2 main reasons:
1. Appallingly managed expectations by many ISP's of "8Mb broadband" as Max rolls out everywhere.
2. Cost-cutting on capacity by Tiscali etc. so actual performance at peak times is terrible.
Re: BT Speedtester.
30-03-2008 3:00 PM
Quote (direct copy and paste)
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, speedtester@bt.com and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Apache/1.3.27 Server at speedtester1.speedtester.bt.com Port 80
So if that is an unknown problem..... somebody wants their posterior well and truly booting....
cp:green Quote tags [quote]... and ... [/quote] added. ][/color]
Re: BT Speedtester.
30-03-2008 9:56 PM
Quote from: artmo The other common message is 'test error'. Once you've entered your phone number and clicked 'go' it takes ages before doing anything and generally I get 'test error'.
Maybe we should all raise this issue with our service providers, as suggested in the attached snapshot
Regards .....
