BT Speedtester - is it broken?
- BT Speedtester - is it broken?
Re: BT Speedtester - is it broken?
22-09-2010 12:58 PM
Quote from: pierre_pierre new Thompson
Wouldn't an M60 be more efficient to aim at BT? Aren't Thompsons a tad dated?
22-09-2010 2:21 PM
22-09-2010 3:26 PM
Quote Download speedachieved during the test was - 6050 Kbps
For your connection, the acceptable range of speedsis 1000-7150 Kbps.
Additional Information:
Your DSL Connection Rate :4164 Kbps(DOWN-STREAM), 744 Kbps(UP-STREAM)
IP Profile for your line is - 3500 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 15.97:17.81:66.23 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
Upload speed achieved during the test was - 341 Kbps
Upstream Rate IP profile on your line is - 744 Kbps
I am actually synching at 14915 Kbps and 440 Kbps upstream, with a PN Ip Profile of 6500. It seems that all PN 21CN connections are affected. Seems that other types are not.
Tony
22-09-2010 5:04 PM
Download speed achieved during the test was - 5129 Kbps
For your connection, the acceptable range of speeds is 1000-7150 Kbps.
Your DSL Connection Rate :3069 Kbps(DOWN-STREAM), 427 Kbps(UP-STREAM)
IP Profile for your line is - 2500 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 10.13:24.06:65.81 (SBE:NBE:PBE)
>Upload speed achieved during the test was - 921 Kbps
Upstream Rate IP profile on your line is - 427 Kbps
22-09-2010 6:54 PM
22-09-2010 8:17 PM
Test time: 22/09/10 19:53
My router reported sync speed is currently 3974 Kbps downstream and 444 Kbps upstream.
My Plusnet reported profile is 4000 and has been since at least May, but I suspect that is duff as well, as I have not connected above 4500 kbps for several weeks (a few weeks after switching to ADSL2+
![Sad Sad](/html/@5863905B9AC6EE4F2B28C1A2965ABC0C/images/emoticons/sad.gif)
My Broadband Speed gives result: 2886 kbps download and 209 kbps. I wouldn't be surprised if I'm on a 3000 kbps
Quote 1. Best Effort Test: -provides background information.
Download speed achieved during the test was - 2095 Kbps
For your connection, the acceptable range of speeds is 100-500 Kbps.
Your DSL Connection Rate :8388 Kbps(DOWN-STREAM), 888 Kbps(UP-STREAM)
IP Profile for your line is - 500 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 6.12:28.06:65.82 (SBE:NBE:PBE)
Upload speed achieved during the test was - 358 Kbps
Upstream Rate IP profile on your line is - 888 Kbps
Edit: added test time
22-09-2010 9:40 PM
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
Quote Download speedachieved during the test was - 5957 Kbps
For your connection, the acceptable range of speedsis 2000-21000 Kbps.
Your DSL Connection Rate :14915 Kbps(DOWN-STREAM), 440 Kbps(UP-STREAM)
IP Profile for your line is - 13000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 19.36:24.59:56.05 (SBE:NBE:PBE)
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
>Upload speed achieved during the test was - 344 Kbps
Upstream Rate IP profile on your line is - 440 Kbps
All of the above match expectations. The low throughout is because of the PN IP profile of 6500 which has yet to be increased.
Tony
22-09-2010 9:52 PM
Just lifted the PN profile to match 13000, you should see it shortly.
Jojo
22-09-2010 10:16 PM
22-09-2010 10:45 PM
Test Results at 22/09/10 22:35
Router reported sync speed is currently 3974 Kbps downstream and 444 Kbps upstream.
Download speed achieved during the test was - 3029 Kbps
Your DSL Connection Rate :3974 Kbps(DOWN-STREAM), 444 Kbps(UP-STREAM)
IP Profile for your line is - 7000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 24.7:26.86:48.44 (SBE:NBE:PBE)
Upload speed achieved during the test was - 357 Kbps
Upstream Rate IP profile on your line is - 444 Kbps
23-09-2010 3:05 PM
Tested at around 14:45 on 2010/09/23
Test1 comprises of two tests
Download Speed
6162 Kbps
0 Kbps 500 Kbps
Max Achievable Speed
Download speed achieved during the test was - 6162 Kbps
Your DSL Connection Rate :283 Kbps(DOWN-STREAM), 212 Kbps(UP-STREAM)
IP Profile for your line is - 350 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 12.08:20.15:67.76 (SBE:NBE:PBE)
Upload Speed
872 Kbps
0 Kbps 212 Kbps
>Upload speed achieved during the test was - 872 Kbps
Upstream Rate IP profile on your line is - 212 Kbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
My router shows the following:
ADSL line status
Connection Information
Line state Connected
Connection time 1 days, 03:34:34
Downstream 16,242 Kbps
Upstream 1,119 Kbps
ADSL Settings
VPI/VCI 0/38
Type PPPoA
Modulation G.992.5 Annex A
Latency type Interleaved
Noise margin (Down/Up) 5.8 dB / 5.3 dB
Line attenuation (Down/Up) 30.1 dB / 12.2 dB
Output power (Down/Up) 24.5 dBm / 1.7 dBm
Loss of Framing (Local/Remote) 0 / 0
Loss of Signal (Local/Remote) 0 / 0
Loss of Power (Local/Remote) 0 / 0
FEC Errors (Down/Up) 7698 / 4
CRC Errors (Down/Up) 1608 / 2
HEC Errors (Down/Up) 63375 / 0
Error Seconds (Local/Remote) 664 / 2
speedtest.net test is looking as good as ever
![](http://www.speedtest.net/result/964422548.png)
mybroadbandspeed.co.uk is looking pretty good too
![](http://www.mybroadbandspeed.co.uk/results/51191761.png)
24-09-2010 7:00 AM
Quote Download speedachieved during the test was - 6429 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 11.31:47.59:41.1 (SBE:NBE:PBE)
Upload speed achieved during the test was - 334 Kbps
However, last evening it was giving rubbish or not finishing. Could it be something to do with demand? Could others try at less busy times and see if they then get sensible results?
Tony
24-09-2010 7:25 AM
Quote from: Tony
Quote Download speed achieved during the test was - 6429 Kbps
It just fell over here at the upload test, 0700, I think there is an element of luck involved.
(Not quite on topic but why the low download result relative the sync rate and profile.)
24-09-2010 8:06 AM
I , no longer believe any speed test.
24-09-2010 8:57 AM
Off topic posts may be split off.
Please make my life easier by sticking to the topic please
