BT Speedtester - is it broken?
- BT Speedtester - is it broken?
Re: BT Speedtester - is it broken?
21-09-2010 11:29 AM
21-09-2010 11:31 AM
21-09-2010 11:34 AM
using http://217.32.105.42:50301/
21-09-2010 12:15 PM
Upstream profile looks OK today but last time I tried it was given as 448, which was silly 'cos actual upload speed was much faster.
PS Line speed according to PlusNet has gone up from 7150 (when I last did the test) to 8000, as sync was faster when I rebooted the router.
Date of test: 21.09.2010
Time of test: 12.00 noon approx
Full Fibre since September 2023
Mac OS14 and Firefox user with latest versions of both
21-09-2010 12:44 PM
They wouldn't fit on one screenshot because my screen isn't big enough, so here it is, in two bits.
It's rubbish though.
21-09-2010 2:08 PM
As Bob asked earlier if you do a test can you also log the time and date for us please.
Thanks for all your help so far.
Jojo
21-09-2010 3:16 PM
Quote from: A They wouldn't fit on one screenshot because my screen isn't big enough, so here it is, in two bits.
What you need is screengrab! which allows you to take a screen shot of the entire page (see attached sample).
21-09-2010 3:46 PM
Using Plusnet speed tester at about 15:37 gave 10368kbs down and 706kbs up which is typical for me.
21-09-2010 4:07 PM
Keep 'em coming
21-09-2010 4:20 PM
Graham
21-09-2010 4:39 PM
21-09-2010 4:42 PM
Graham
1. Best Effort Test: -provides background information.
Download Speed
7877 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speed achieved during the test was - 7877 Kbps
For your connection, the acceptable range of speeds is 1000-7150 Kbps.
Additional Information:
Your DSL Connection Rate :8127 Kbps(DOWN-STREAM), 443 Kbps(UP-STREAM)
IP Profile for your line is - 7150 Kbps
Upload Speed
654 Kbps
0 Kbps 443 Kbps
>Upload speed achieved during the test was - 654 Kbps
Upstream Rate IP profile on your line is - 443 Kbps
21-09-2010 4:48 PM
21-09-2010 4:52 PM
21-09-2010 6:00 PM
Quote from: jelv What you need is screengrab! which allows you to take a screen shot of the entire page...
Thanks jelv
I've got it now.
