BT Speedtester Query
- BT Speedtester Query
27-07-2010 3:56 PM
This is NOT a Plusnet question because AFAIK it does not apply to Plusnet but what does it mean if the BT speed tester at http://speedtester.bt.com/ doesn't give you an IP Profile (as happened this morning testing a Tiscali line). Does that mean it is a fixed (max.) line rate service and so not subject the the vagaries of BT's DLM system?
Message 1 of 5
(850 Views)
4 REPLIES 4
Re: BT Speedtester Query
27-07-2010 4:02 PM
If there isn't any mention of a profile it usually means you are on a fixed rate line not Max on a BT line but in the case of LLU (aka Tiscali) then there just isn't an IP profile and you get the maximum speed with no stupid restrictions
Actually I didn't think the Bt speedtest worked on LLU so it may be a fixed speed BT line
Message 2 of 5
(447 Views)
27-07-2010 4:17 PM
It certainly won't work on my LLU line.
Message 3 of 5
(447 Views)
27-07-2010 7:04 PM
No, sorry, I forgot to mention there is no LUU at this telephone exchange.
Message 4 of 5
(447 Views)
27-07-2010 8:27 PM
The easy way to check is look at the upstream sync
Message 5 of 5
(447 Views)
