BT Speedtest
- BT Speedtest
BT Speedtest
18-10-2010 1:26 PM
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
16239 Kbps
0 Kbps 21000 Kbps
Max Achievable Speed
Download speedachieved during the test was - 16239 Kbps
For your connection, the acceptable range of speedsis 4000-21000 Kbps.
Additional Information:
Your DSL Connection Rate :0 Kbps(DOWN-STREAM), 0 Kbps(UP-STREAM)
IP Profile for your line is - 16000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 16.78:22.37:60.86 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
If you wish to discuss these results please contact your ISP.
If you are experiencing problems with specific applications, servers or websites please contact your ISP for assistance.
Your test has completed please close this window to exit the performance tester.
Note: An Upstream test was not conducted on this line due to a technical issue. If your concern is related to upstream performance then please retry
the performance test again in 1 hours time.
Please visit FAQ section if you are unable To understand the test results.
Java Read Out
Java Plug-in 1.6.0_21
Using JRE version 1.6.0_21-b07 Java HotSpot(TM) Client VM
User home directory = C:\Users\Paul
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to <n>
network: Cache entry found [url: http://217.32.105.42:8080/applet/progressbar/SimultaneouslyTestHandler.class, version: null] prevalidated=false/0
network: Connecting http://217.32.105.42:8080/applet/progressbar/SimultaneouslyTestHandler.class with proxy=DIRECT
network: Connecting http://217.32.105.42:8080/ with proxy=DIRECT
network: ResponseCode for http://217.32.105.42:8080/applet/progressbar/SimultaneouslyTestHandler.class : 304
network: Encoding for http://217.32.105.42:8080/applet/progressbar/SimultaneouslyTestHandler.class : null
network: Disconnect connection to http://217.32.105.42:8080/applet/progressbar/SimultaneouslyTestHandler.class
network: Cache entry not found [url: http://217.32.105.42:7778/download/file/testdata.dat?test=NBETEST&random=0.07140759856986567, version: null]
network: Cache entry not found [url: http://217.32.105.42:7778/download/file/testdata.dat?test=PBETEST&random=0.9684786863932637, version: null]
network: Cache entry not found [url: http://217.32.105.42:7778/download/file/testdata.dat?test=SBETEST&random=0.250859441106549, version: null]
network: Connecting http://217.32.105.42:7778/download/file/testdata.dat?test=NBETEST&random=0.07140759856986567 with proxy=DIRECT
network: Connecting http://217.32.105.42:7778/download/file/testdata.dat?test=SBETEST&random=0.250859441106549 with proxy=DIRECT
network: Connecting http://217.32.105.42:7778/download/file/testdata.dat?test=PBETEST&random=0.9684786863932637 with proxy=DIRECT
network: Connecting http://217.32.105.42:7778/ with proxy=DIRECT
network: Cache entry found [url: http://217.32.105.42:8080/applet/progressbar/ImageLoader.class, version: null] prevalidated=false/0
network: Connecting http://217.32.105.42:8080/applet/progressbar/ImageLoader.class with proxy=DIRECT
network: ResponseCode for http://217.32.105.42:8080/applet/progressbar/ImageLoader.class : 304
network: Encoding for http://217.32.105.42:8080/applet/progressbar/ImageLoader.class : null
network: Disconnect connection to http://217.32.105.42:8080/applet/progressbar/ImageLoader.class
network: Cache entry not found [url: http://217.32.105.42:7778/download/file/testdata.dat?test=NBETEST&random=0.5870828393062444, version: null]
network: Cache entry not found [url: http://217.32.105.42:7778/download/file/testdata.dat?test=SBETEST&random=0.4408854516363022, version: null]
network: Connecting http://217.32.105.42:7778/download/file/testdata.dat?test=NBETEST&random=0.5870828393062444 with proxy=DIRECT
network: Cache entry not found [url: http://217.32.105.42:7778/download/file/testdata.dat?test=PBETEST&random=0.6933206223301597, version: null]
network: Cache entry not found [url: http://217.32.105.42:7778/download/file/testdata.dat?test=SBETEST&random=0.18941081280944827, version: null]
network: Connecting http://217.32.105.42:7778/download/file/testdata.dat?test=PBETEST&random=0.6933206223301597 with proxy=DIRECT
network: Connecting http://217.32.105.42:7778/download/file/testdata.dat?test=SBETEST&random=0.18941081280944827 with proxy=DIRECT
network: Cache entry not found [url: http://217.32.105.42:7778/download/file/testdata.dat?test=PBETEST&random=0.6744156120173794, version: null]
network: Cache entry not found [url: http://217.32.105.42:7778/download/file/testdata.dat?test=NBETEST&random=0.33695982644422573, version: null]
network: Connecting http://217.32.105.42:7778/download/file/testdata.dat?test=PBETEST&random=0.6744156120173794 with proxy=DIRECT
network: Cache entry not found [url: http://217.32.105.42:7778/download/file/testdata.dat?test=PBETEST&random=0.5432824419709367, version: null]
network: Cache entry not found [url: http://217.32.105.42:7778/download/file/testdata.dat?test=NBETEST&random=0.7399956075984115, version: null]
network: Connecting http://217.32.105.42:7778/download/file/testdata.dat?test=PBETEST&random=0.5432824419709367 with proxy=DIRECT
network: Connecting http://217.32.105.42:7778/download/file/testdata.dat?test=NBETEST&random=0.33695982644422573 with proxy=DIRECT
network: Connecting http://217.32.105.42:7778/download/file/testdata.dat?test=NBETEST&random=0.7399956075984115 with proxy=DIRECT
network: Cache entry not found [url: http://217.32.105.42:7778/download/file/testdata.dat?test=NBETEST&random=0.09342007978702904, version: null]
network: Connecting http://217.32.105.42:7778/download/file/testdata.dat?test=NBETEST&random=0.09342007978702904 with proxy=DIRECT
network: Cache entry not found [url: http://217.32.105.42:7778/download/file/testdata.dat?test=PBETEST&random=0.4283366340909365, version: null]
network: Connecting http://217.32.105.42:7778/download/file/testdata.dat?test=PBETEST&random=0.4283366340909365 with proxy=DIRECT
network: Cache entry not found [url: http://217.32.105.42:7778/download/file/testdata.dat?test=PBETEST&random=0.979740344281195, version: null]
network: Connecting http://217.32.105.42:7778/download/file/testdata.dat?test=PBETEST&random=0.979740344281195 with proxy=DIRECT
network: Cache entry found [url: http://217.32.105.42:8080/applet/progressbar/ImageProgressLoader.class, version: null] prevalidated=false/0
network: Connecting http://217.32.105.42:8080/applet/progressbar/ImageProgressLoader.class with proxy=DIRECT
network: Cache entry not found [url: http://217.32.105.42:7778/download/file/testdata.dat?test=PBETEST&random=0.5212813646815746, version: null]
network: Connecting http://217.32.105.42:7778/download/file/testdata.dat?test=SBETEST&random=0.4408854516363022 with proxy=DIRECT
network: Connecting http://217.32.105.42:7778/download/file/testdata.dat?test=PBETEST&random=0.5212813646815746 with proxy=DIRECT
network: Cache entry not found [url: http://217.32.105.42:7778/download/file/testdata.dat?test=SBETEST&random=0.5024690492367705, version: null]
network: Cache entry not found [url: http://217.32.105.42:7778/download/file/testdata.dat?test=PBETEST&random=0.008265904607038799, version: null]
network: Connecting http://217.32.105.42:7778/download/file/testdata.dat?test=SBETEST&random=0.5024690492367705 with proxy=DIRECT
network: Cache entry not found [url: http://217.32.105.42:7778/download/file/testdata.dat?test=PBETEST&random=0.5619044385462474, version: null]
network: Connecting http://217.32.105.42:7778/download/file/testdata.dat?test=PBETEST&random=0.5619044385462474 with proxy=DIRECT
network: Connecting http://217.32.105.42:7778/download/file/testdata.dat?test=PBETEST&random=0.008265904607038799 with proxy=DIRECT
network: Cache entry not found [url: http://217.32.105.42:7778/download/file/testdata.dat?test=SBETEST&random=0.43396140202010847, version: null]
network: Connecting http://217.32.105.42:7778/download/file/testdata.dat?test=SBETEST&random=0.43396140202010847 with proxy=DIRECT
network: ResponseCode for http://217.32.105.42:8080/applet/progressbar/ImageProgressLoader.class : 304
network: Encoding for http://217.32.105.42:8080/applet/progressbar/ImageProgressLoader.class : null
network: Disconnect connection to http://217.32.105.42:8080/applet/progressbar/ImageProgressLoader.class
No upload test at all..
http://www.btwholesale.com/pages/downloads/Community/Broadband_Community/PT_Customer_handbook_v6.pdf
Re: BT Speedtest
18-10-2010 3:03 PM
I'm not really sure what the question is there but I'd noticed that your BT profile had gone to 17000 so I've just matched ours to it.
Jojo
Re: BT Speedtest
18-10-2010 3:16 PM
Re: BT Speedtest
18-10-2010 3:25 PM
Re: BT Speedtest
18-10-2010 11:44 PM
g: garbage collect
o: trigger logging
q: hide console
t: dump thread list
security: property package.access value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.
security: property package.access new value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.,com.sun.javaws
security: property package.access value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.,com.sun.javaws
security: property package.access new value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.,com.sun.javaws,com.sun.deploy
security: property package.access value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.,com.sun.javaws,com.sun.deploy
security: property package.access new value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.,com.sun.javaws,com.sun.deploy,com.sun.jnlp
security: property package.definition value null
security: property package.definition new value com.sun.javaws
security: property package.definition value com.sun.javaws
security: property package.definition new value com.sun.javaws,com.sun.deploy
security: property package.definition value com.sun.javaws,com.sun.deploy
security: property package.definition new value com.sun.javaws,com.sun.deploy,com.sun.jnlp
security: property package.access value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.,com.sun.javaws,com.sun.deploy,com.sun.jnlp
security: property package.access new value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.,com.sun.javaws,com.sun.deploy,com.sun.jnlp,org.mozilla.jss
security: property package.definition value com.sun.javaws,com.sun.deploy,com.sun.jnlp
security: property package.definition new value com.sun.javaws,com.sun.deploy,com.sun.jnlp,org.mozilla.jss
basic: Added progress listener: sun.plugin.util.GrayBoxPainter$GrayBoxProgressListener@5b0668
network: Cache entry not found [url: http://217.35.209.142:8080/applet/progressbar/, version: null]
network: Cache entry found [url: http://217.35.209.142:8080/applet/progressbar/ProgressBarPT.class, version: null] prevalidated=false/0
network: Connecting http://217.35.209.142:8080/applet/progressbar/ProgressBarPT.class with proxy=DIRECT
network: Connecting http://217.35.209.142:8080/ with proxy=DIRECT
network: ResponseCode for http://217.35.209.142:8080/applet/progressbar/ProgressBarPT.class : 304
network: Encoding for http://217.35.209.142:8080/applet/progressbar/ProgressBarPT.class : null
network: Disconnect connection to http://217.35.209.142:8080/applet/progressbar/ProgressBarPT.class
network: Cache entry found [url: http://217.35.209.142:8080/applet/progressbar/ProgressBar.class, version: null] prevalidated=false/0
network: Connecting http://217.35.209.142:8080/applet/progressbar/ProgressBar.class with proxy=DIRECT
network: ResponseCode for http://217.35.209.142:8080/applet/progressbar/ProgressBar.class : 304
network: Encoding for http://217.35.209.142:8080/applet/progressbar/ProgressBar.class : null
network: Disconnect connection to http://217.35.209.142:8080/applet/progressbar/ProgressBar.class
basic: Applet loaded.
basic: Applet resized and added to parent container
basic: PERF: AppletExecutionRunnable - applet.init() BEGIN ; jvmLaunch dt 3912748 us, pluginInit dt 3779188 us, TotalTime: 7691936 us
network: Cache entry not found [url: http://217.35.209.142:8080/applet/progressbar/PBENBESBE.properties, version: null]
network: Connecting http://217.35.209.142:8080/applet/progressbar/PBENBESBE.properties with proxy=DIRECT
Initializing...
basic: Applet initialized
basic: Removed progress listener: sun.plugin.util.GrayBoxPainter$GrayBoxProgressListener@5b0668
basic: Applet made visible
basic: Starting applet
basic: completed perf rollup
In start method 1
basic: Applet started
basic: Told clients applet is started
network: Cache entry found [url: http://217.35.209.142:8080/applet/progressbar/SimultaneouslyTestHandler.class, version: null] prevalidated=false/0
network: Connecting http://217.35.209.142:8080/applet/progressbar/SimultaneouslyTestHandler.class with proxy=DIRECT
network: ResponseCode for http://217.35.209.142:8080/applet/progressbar/SimultaneouslyTestHandler.class : 304
network: Encoding for http://217.35.209.142:8080/applet/progressbar/SimultaneouslyTestHandler.class : null
network: Disconnect connection to http://217.35.209.142:8080/applet/progressbar/SimultaneouslyTestHandler.class
network: Cache entry not found [url: http://217.35.209.142:7778/download/file/testdata.dat?test=PBETEST&random=0.08124881006128992, version: null]
network: Cache entry not found [url: http://217.35.209.142:7778/download/file/testdata.dat?test=NBETEST&random=0.07946517827348842, version: null]
network: Cache entry not found [url: http://217.35.209.142:7778/download/file/testdata.dat?test=SBETEST&random=0.20218157729735386, version: null]
network: Connecting http://217.35.209.142:7778/download/file/testdata.dat?test=NBETEST&random=0.07946517827348842 with proxy=DIRECT
network: Connecting http://217.35.209.142:7778/download/file/testdata.dat?test=PBETEST&random=0.08124881006128992 with proxy=DIRECT
network: Connecting http://217.35.209.142:7778/download/file/testdata.dat?test=SBETEST&random=0.20218157729735386 with proxy=DIRECT
network: Connecting http://217.35.209.142:7778/ with proxy=DIRECT
network: Cache entry found [url: http://217.35.209.142:8080/applet/progressbar/ImageLoader.class, version: null] prevalidated=false/0
network: Connecting http://217.35.209.142:8080/applet/progressbar/ImageLoader.class with proxy=DIRECT
network: ResponseCode for http://217.35.209.142:8080/applet/progressbar/ImageLoader.class : 304
network: Encoding for http://217.35.209.142:8080/applet/progressbar/ImageLoader.class : null
network: Disconnect connection to http://217.35.209.142:8080/applet/progressbar/ImageLoader.class
network: Cache entry not found [url: http://217.35.209.142:7778/download/file/testdata.dat?test=PBETEST&random=0.07465373583693247, version: null]
network: Cache entry not found [url: http://217.35.209.142:7778/download/file/testdata.dat?test=PBETEST&random=0.18352404227256325, version: null]
network: Connecting http://217.35.209.142:7778/download/file/testdata.dat?test=PBETEST&random=0.18352404227256325 with proxy=DIRECT
network: Cache entry not found [url: http://217.35.209.142:7778/download/file/testdata.dat?test=PBETEST&random=0.6607527220956444, version: null]
network: Connecting http://217.35.209.142:7778/download/file/testdata.dat?test=PBETEST&random=0.07465373583693247 with proxy=DIRECT
network: Connecting http://217.35.209.142:7778/download/file/testdata.dat?test=PBETEST&random=0.6607527220956444 with proxy=DIRECT
network: Cache entry not found [url: http://217.35.209.142:7778/download/file/testdata.dat?test=PBETEST&random=0.30201557094141296, version: null]
network: Connecting http://217.35.209.142:7778/download/file/testdata.dat?test=PBETEST&random=0.30201557094141296 with proxy=DIRECT
network: Cache entry not found [url: http://217.35.209.142:7778/download/file/testdata.dat?test=PBETEST&random=0.34223709709245587, version: null]
network: Connecting http://217.35.209.142:7778/download/file/testdata.dat?test=PBETEST&random=0.34223709709245587 with proxy=DIRECT
network: Cache entry not found [url: http://217.35.209.142:7778/download/file/testdata.dat?test=PBETEST&random=0.6328038226284449, version: null]
network: Connecting http://217.35.209.142:7778/download/file/testdata.dat?test=PBETEST&random=0.6328038226284449 with proxy=DIRECT
network: Cache entry found [url: http://217.35.209.142:8080/applet/progressbar/ImageProgressLoader.class, version: null] prevalidated=false/0
network: Connecting http://217.35.209.142:8080/applet/progressbar/ImageProgressLoader.class with proxy=DIRECT
network: Cache entry not found [url: http://217.35.209.142:7778/download/file/testdata.dat?test=NBETEST&random=0.7472635234215032, version: null]
network: Cache entry not found [url: http://217.35.209.142:7778/download/file/testdata.dat?test=NBETEST&random=0.5366150223688814, version: null]
network: Cache entry not found [url: http://217.35.209.142:7778/download/file/testdata.dat?test=SBETEST&random=0.1346656975650925, version: null]
network: Cache entry not found [url: http://217.35.209.142:7778/download/file/testdata.dat?test=PBETEST&random=0.21687181682410805, version: null]
network: Connecting http://217.35.209.142:7778/download/file/testdata.dat?test=NBETEST&random=0.5366150223688814 with proxy=DIRECT
network: Connecting http://217.35.209.142:7778/download/file/testdata.dat?test=NBETEST&random=0.7472635234215032 with proxy=DIRECT
network: Cache entry not found [url: http://217.35.209.142:7778/download/file/testdata.dat?test=SBETEST&random=0.006184718444674164, version: null]
network: Cache entry not found [url: http://217.35.209.142:7778/download/file/testdata.dat?test=SBETEST&random=0.13758096375264173, version: null]
network: Cache entry not found [url: http://217.35.209.142:7778/download/file/testdata.dat?test=NBETEST&random=0.051986695828283636, version: null]
network: Connecting http://217.35.209.142:7778/download/file/testdata.dat?test=SBETEST&random=0.006184718444674164 with proxy=DIRECT
network: Cache entry not found [url: http://217.35.209.142:7778/download/file/testdata.dat?test=SBETEST&random=0.15157788008122408, version: null]
network: Connecting http://217.35.209.142:7778/download/file/testdata.dat?test=SBETEST&random=0.13758096375264173 with proxy=DIRECT
network: Connecting http://217.35.209.142:7778/download/file/testdata.dat?test=NBETEST&random=0.051986695828283636 with proxy=DIRECT
network: Connecting http://217.35.209.142:7778/download/file/testdata.dat?test=PBETEST&random=0.21687181682410805 with proxy=DIRECT
network: Cache entry not found [url: http://217.35.209.142:7778/download/file/testdata.dat?test=NBETEST&random=0.35079781536508003, version: null]
network: Connecting http://217.35.209.142:7778/download/file/testdata.dat?test=NBETEST&random=0.35079781536508003 with proxy=DIRECT
network: Connecting http://217.35.209.142:7778/download/file/testdata.dat?test=SBETEST&random=0.15157788008122408 with proxy=DIRECT
network: Cache entry not found [url: http://217.35.209.142:7778/download/file/testdata.dat?test=PBETEST&random=0.8811705353573626, version: null]
network: Connecting http://217.35.209.142:7778/download/file/testdata.dat?test=PBETEST&random=0.8811705353573626 with proxy=DIRECT
network: Connecting http://217.35.209.142:7778/download/file/testdata.dat?test=SBETEST&random=0.1346656975650925 with proxy=DIRECT
network: ResponseCode for http://217.35.209.142:8080/applet/progressbar/ImageProgressLoader.class : 304
network: Encoding for http://217.35.209.142:8080/applet/progressbar/ImageProgressLoader.class : null
network: Disconnect connection to http://217.35.209.142:8080/applet/progressbar/ImageProgressLoader.class
Performing UpstreamTest(888,TAP1,30,4)
network: Cache entry not found [url: http://217.35.209.142:8080/applet/progressbar/DataUploader.class, version: null]
network: Connecting http://217.35.209.142:8080/applet/progressbar/DataUploader.class with proxy=DIRECT
network: Downloading resource: http://217.35.209.142:8080/applet/progressbar/DataUploader.class
Content-Length: 3,625
Content-Encoding: null
network: Wrote URL http://217.35.209.142:8080/applet/progressbar/DataUploader.class to File C:\Users\Paul\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\15\5972344f-3abcaea3-temp
network: Cache entry not found [url: http://217.35.209.142:8080/applet/progressbar/DataUploadProgressLoader.class, version: null]
network: Connecting http://217.35.209.142:8080/applet/progressbar/DataUploadProgressLoader.class with proxy=DIRECT
network: CleanupThread used 90302 us
network: CleanupThread used 6 us
network: Downloading resource: http://217.35.209.142:8080/applet/progressbar/DataUploadProgressLoader.class
Content-Length: 1,876
network: Wrote URL http://217.35.209.142:8080/applet/progressbar/DataUploadProgressLoader.class to File C:\Users\Paul\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\34\78db3122-5696513c-temp
Mon Oct 18 23:25:25 BST 2010 ServerResponse - File Bytes read :: 680166
Mon Oct 18 23:25:25 BST 2010 ServerResponse - File Bytes read :: 666248
Mon Oct 18 23:25:25 BST 2010 ServerResponse - File Bytes read :: 719781
Mon Oct 18 23:25:25 BST 2010 ServerResponse - File Bytes read :: 700646
Re: BT Speedtest
19-10-2010 7:22 AM
i suppose another geek got control over how the test is run..
Re: BT Speedtest
19-10-2010 8:51 AM
(only that you ARE a geek ! ! )
Re: BT Speedtest
19-10-2010 9:05 AM
jim:quote
Re: BT Speedtest
19-10-2010 9:46 AM
http://speedtester.bt.com was giving the kind of result you got when no upload test was done, whereas
http://www.speedtester.bt.com was reporting correct (or at least plausible) results.
You could see if that's the same for you.
Graham
Re: BT Speedtest
19-10-2010 10:34 AM
Phone exchange:
BRAINTREE
Estimated line speed:
8 - Checked on 2009-08-09 03:31:10
Current line speed:
14000
Re: BT Speedtest
19-10-2010 11:05 AM
Graham
Re: BT Speedtest
19-10-2010 11:19 AM
With and without results
Yesterday 19:04 3841 kbps (480kB/s) 196 kbps (24.5kB/s)
Yesterday 19:02 11612 kbps (1.45MB/s) 775 kbps (96.9kB/s)
Re: BT Speedtest
19-10-2010 1:30 PM
Quote from: grahamt Paula,
All i can say Gwynneth is i always use both speedtest servers. if you read the bt tester pdf, you will see how all the tests are laid out.
But i did not realise you where an expert..
