BT Speedtest stopped working
vetterlein
Having just had FTTC installed , try to see if my speed might improve.
originally BT speedtester (FTTC mode) worked fine ... but recently (day or so) it just says:
"An Error has occurred"
Is this just me? Or did it actually break?
11 REPLIES 11
jamesanstee
Re: BT Speedtest stopped working
I get the same thing with the bt speedtester try this one as it seems to work better http://speedtest.btwholesale.com/
Fixes: 1,483
the flash one doesn't give you the profile though, which is often the reason for using the bt speedtest.
Lorian
back-rev java it doesn't work with the latest version.
definitely works with 1.5.0_07B03
w23
Fixes: 4
Quote from: dvorak
if you mean  http://speedtest.btwholesale.com/ ; then it does give the profile if you select 'further diagnostics' after completing the initial speed test.
Call me 'w23'
Bald_Eagle1
Quote from: Lorian
Also works with this one (build 1.6.0_31-b05)
vetterlein
Wow ... thought things were getting worse (Fibre extra ...)
BT Wholesale Broadband Performance Test
Broadband Speed Test Results
down 25,84
up 9.23
ping 24.25
...maybe it just slopes down so it's impossible to hit 250Gb download 😞
This month you've used
4.21GB
of your 250GB allowance
by 10Gb maybe I'll drop below 1.0mbps
Anotherone
Champion
Fixes: 21
Further Diagnostics is the same as Diagnostics on the previous tester link
See http://community.plus.net/forum/index.php/topic,108009.msg922208.html#msg922208 also note the comment about Java RTE.
chrispurvey
Are you using a wired or wireless connection?
vetterlein
It was wireless ... wired normal goes through a proxy.
I just connected a rather fast laptop direct to the 582.... also spotted the FFTP (beta) links in BT speedtest for > 24mps and tried that and got:
down 35.27
up      10.07
ping  25.88
...which I think of a poor ... but having seen the figures some folks are getting , I should count myself lucky.
(Rather annoyingly the BT Engineer pointed , my copper pair does not come from 12 doors up the road (nice new box) , nor the older one across the road from that  .... but several streets along, over a railway bridge (electric 3rd rail)  and by some local shops .... sigh
Anotherone
Champion
Fixes: 21
Huh, yuk, I'd have asked about the chances of getting it re-routed  Crazy
chrispurvey
At least your speeds are back to your line estimates.
