BT Speedtest stopped working
- BT Speedtest stopped working
06-10-2012 8:34 PM
originally BT speedtester (FTTC mode) worked fine ... but recently (day or so) it just says:
"An Error has occurred"
Is this just me? Or did it actually break?
Re: BT Speedtest stopped working
06-10-2012 9:09 PM
06-10-2012 9:31 PM
07-10-2012 12:29 AM
definitely works with 1.5.0_07B03
07-10-2012 2:52 AM
Quote from: dvorak the flash one doesn't give you the profile though, which is often the reason for using the bt speedtest.
if you mean http://speedtest.btwholesale.com/ ; then it does give the profile if you select 'further diagnostics' after completing the initial speed test.
07-10-2012 10:11 AM
Quote from: Lorian
Also works with this one (build 1.6.0_31-b05)
07-10-2012 6:30 PM
BT Wholesale Broadband Performance Test
Broadband Speed Test Results
down 25,84
up 9.23
ping 24.25
...maybe it just slopes down so it's impossible to hit 250Gb download 😞
This month you've used
4.21GB
of your 250GB allowance
by 10Gb maybe I'll drop below 1.0mbps
07-10-2012 9:27 PM
See http://community.plus.net/forum/index.php/topic,108009.msg922208.html#msg922208 also note the comment about Java RTE.
08-10-2012 11:25 AM
09-10-2012 9:38 PM
I just connected a rather fast laptop direct to the 582.... also spotted the FFTP (beta) links in BT speedtest for > 24mps and tried that and got:
down 35.27
up 10.07
ping 25.88
...which I think of a poor ... but having seen the figures some folks are getting , I should count myself lucky.
(Rather annoyingly the BT Engineer pointed , my copper pair does not come from 12 doors up the road (nice new box) , nor the older one across the road from that .... but several streets along, over a railway bridge (electric 3rd rail) and by some local shops .... sigh
09-10-2012 11:03 PM
10-10-2012 10:02 AM
