BT Speedtest and IP profile screwed
- BT Speedtest and IP profile screwed
09-05-2012 6:14 PM
IP Profile for your line is - 3.67 Mbps
Using the 88.2% rule that should give a sync speed of about 4160kbps
However my line hasn't had a sync that low since the 29th April
At present it has been 4896kbps for the last 32 hours and before that 4704kbps
Just to add - Current line speed: 4.1 Mb
Also second picture of my line speed changes against time
Further information - I resynched the connection at about 09.25 on the 30th April - sync 4672kbps and then did the following speed test which matches the IP profile of 4120kbps by the 88.2% rule
Re: BT Speedtest and IP profile screwed
09-05-2012 10:15 PM
I've just ran a check and your current sync rate is 4160 with an IP profile of 3.67Mbps. This is with an SNR of 5dB. Did you not used to get more than that?
Jojo
10-05-2012 9:43 AM
Noise Margin: 4.9 dB
Connection Rate: 4896 Kbps
Line Attenuation: 50.0 dB
The last time it was 4160kbps was on the 20th January 2012 at about 23.20
10-05-2012 3:05 PM
Download speedachieved during the test was - 3.4 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
10-05-2012 3:43 PM
10-05-2012 4:12 PM
For an unknown reason my router lost sync at 15.34 and resynched at 4,800kbps
BT speedtester now correct
Quote Download speedachieved during the test was - 3.9 Mbps
IP Profile for your line is - 4.23 Mbps
I am not sure where you got the 4319kbps profile from as that was from the earlier sync rate of 4,896kbps
So something still isn't correct
10-05-2012 4:22 PM
BT ADSL/FTTC Performance Tester - 7.68/0.9 d/u
BT Lite (beta) - 9.05/1.0 Ping 39ms
Speedtest.net - 9.04/1.02 Ping 30ms
These are significant variations between the "official" BT tester and it's on-trial sibling, and have been pretty consistent for a few weeks now. They clearly can't both be right - I hope BT manage to produce a tester we can all feel consistently confident about sooner rather than later!
10-05-2012 4:55 PM
10-05-2012 4:57 PM
11-05-2012 5:20 PM
Quote from: Joanne Hi Jim.
Jojo
Any chance of some thoughts as to why the discrepancy
Quote from: Oldjim No it isn't
11-05-2012 5:26 PM
I'm afraid I'm just going to have to go with exchange blip I'm afraid. Glad it's sorted now though.
