BT Speedtest Problem.
- Re: BT Speedtest Problem.
16-04-2012 10:41 AM
Test Error
You have already completed 1 full speed tests within an hour. The Performance Tester will only allow one test to be complete every 60 minutes.
This was the first test attempt today after an 8 hour sleep for myself and my computer. Previous attempts have been spaced at least 2-3hours apart.
Maybe a router reboot is required later today.
Edit: I'm not on ADSL2+ or fibre although my cabinet is fibre enabled.
It may have coincidently started the problem around the time fibre was made available on the line.
16-04-2012 11:13 AM
I blame it on the folk testing how fast their fibre connections are
16-04-2012 11:27 AM
Oh well maybe I should place an order for fibre.
Update: I have rebooted my router and run a successful BT speed test. I did actually run it using only the service ID but will try with just my phone number in an hour or so.
16-04-2012 2:26 PM
I then repeated the test just using my service ID and it worked fine
I'm assuming here that my service ID hasn't changed recently.
16-04-2012 3:33 PM
16-04-2012 3:40 PM
16-04-2012 3:49 PM
16-04-2012 4:15 PM
Quote from the site...
Quote Down for the moment as BT have changed their systems. Find a way to tell me and I will try and fix it..
16-04-2012 4:33 PM
I've replied to your PM.
Jojo
16-04-2012 7:29 PM
Last week an OR engineer was looking into a voice fault for a nearby neighbour and after several hours had to replace part of the main cable according to the neighbour once he found it down in the woods (very rural location), he thought a good deal of the cable should be replaced but BT OR don't do prevention only cure due to budget restraints
16-04-2012 10:11 PM
16-04-2012 10:25 PM
Quote I didn't get .....
I actually sent Jojo a PM to see if she could inform me of the ID by PM ........... so don't feel too bad
16-04-2012 10:38 PM
17-04-2012 12:11 AM
Quote type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
java.lang.IllegalStateException: Cannot forward after response has been committed
org.apache.struts.action.RequestProcessor.doForward(RequestProcessor.java:1078)
org.apache.struts.action.RequestProcessor.processForwardConfig(RequestProcessor.java:396)
org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:232)
org.apache.struts.action.ActionServlet.process(ActionServlet.java:1913)
org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:462)
javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
17-04-2012 9:43 AM
