BT Speed tester hangs at 96%
- BT Speed tester hangs at 96%
03-08-2008 4:53 PM
Incidentally at a connection speed 6080 and profile 5000 the max speed I've seen with the My BB speed tester has been around 4200 and sometimes down to the 2500 mark.
Could there be some link between the low speed and the error shown?
Re: BT Speed tester hangs at 96%
03-08-2008 4:55 PM
03-08-2008 4:58 PM
03-08-2008 5:16 PM
03-08-2008 5:39 PM
03-08-2008 5:51 PM
Houston we seem to have a problem
I could not find IE in my list of progs, so downloaded again and installed. Still couldn't find it, downloaded again and installed with same result. Where the dickens is it hiding, or do you actually and really go to IE, if you click the IE icon in Firefox?
03-08-2008 5:53 PM
03-08-2008 6:04 PM
03-08-2008 7:00 PM
FWIW result is attached and thst is at higher end of what I've been getting
03-08-2008 7:18 PM
03-08-2008 8:35 PM
Even then, it only seems to 96% work in a 32bit version of FireFox.
It works 0% in my usual 64bit browser.
Since every other site works 100%, why can't BT manage to get it working?
Why do they use Java - all the work is done at the server side isn't it?
BTW I don't have (or want) access to the ie browser.
03-08-2008 8:58 PM
03-08-2008 9:13 PM
I can guarantee that this is the answer, there is a recent thread http://community.plus.net/forum/index.php/topic,66802.0.html
03-08-2008 10:07 PM
Firefox is up to date version 3.0.1
Java is up to date Version 6 Update 7 (build 1.6.0_07-b06)
And it still stalls
04-08-2008 7:31 PM
Wuz
