BT Speed test IP profile stuck at 2000kbps on a healthy adsl line
- BT Speed test IP profile stuck at 2000kbps on a he...
18-12-2011 8:29 PM
As title states I have a healthy ADSL line which should equate to an IP profile of 7150 kbps. However I have a BT IP profile of 2000 kbps and its been lik ethis for a number of weeks with noticeably decreased performance. I logged a ticket via Plusnet a week ago and was told some automatic restrictions were on my line which had been reset 24 hours ago. I still have the same issue. Can someone help get my BT speedtest IP profile set to 7150 kbps. According to Plusnet the profile they see is 7150 but I do not see this with BT speedtest results, I assume the profile is stuck on BT wholesale side for some reason.
Message 1 of 3
(848 Views)
2 REPLIES 2
Re: BT Speed test IP profile stuck at 2000kbps on a healthy adsl line
18-12-2011 8:34 PM
more likely a mismatch between two BT systems - hopefully will be picked up on Monday
Message 2 of 3
(370 Views)
18-12-2011 8:39 PM
I hope so as its running slow at the moment and has been for a few months. Very frustrating as I have a good sync speed etc on the line but BT wholesale think it isnt
ADSL Status
Parameters
DSP Firmware Version A2pB025f.d22k
DMT Status No Defect
Operational Mode G.DMT
Upstream 448
Downstream 8128
SNR Margin(Upstream) 20.0
SNR Margin(Downstream) 7.8
Line Attenuation(Upstream) 14.0
Line Attenuation(Downstream) 23.0
ADSL Status
Parameters
Upstream 448
Downstream 8128
Message 3 of 3
(370 Views)
