BT Speed profile - How do I improve it?
TornadoRush
My line has been good to go at between ~ 4500k and 5500k  but recently my router has been rebooted a few times and now my IP profile is 3500.  Can anyone explain how this can be increased or what the factors are that affect the profile?
Also I am currently waiting for interleaving be switched off and I wanted to find out if this has an effect on the profile too?
IP profile for your line is - 3500 kbps
    DSL connection rate: 832 kbps(UP-STREAM)  4896 kbps(DOWN-STREAM)
    Actual IP throughput achieved during the test was - 3235 kbps
Thanks in advance for any light you can shed!  Cheesy
VileReynard
Seasoned Pro
Fixes: 10
Re: BT Speed profile - How do I improve it?
Interleaving should have no effect on your profile.
If you have very few errors, switching off interleaving will give a small increase in speed and a worthwhile decrease in ping times.
If you have many errors, switching off interleaving will drastically slow your speed.
4896 kbps(DOWN-STREAM) should give you a 4000Kbps profile.
Fixes: 52
Your IP Profile should increase automatically to 4000kbps in 3-4 days if you remain synced above 4544kbps throughout that period.
Unfortunately its the way maxDSL works.
David
TornadoRush
Thanks for the info.
Would the following stats imply I have a high number of errors that will actually mean I have slower speeds when interleaving is switched off?  Undecided
Uptime - 36 hours
Mode: G.DMT
Type: Interleave
Line Coding: Trellis Off
Status: No Defect
  Downstream Upstream
Rate (Kbps): 4896  832
SNR Margin (dB): 7.1  10.0
Attenuation (dB): 47.0  27.0
Output Power (dBm): 11.9  19.6
Super Frames: 7686106  7686104
Super Frame Errors: 738  157
RS Words: 522655254  65331884
RS Correctable Errors: 15019914  416
RS Uncorrectable Errors: 11415  N/A
HEC Errors: 670  137
OCD Errors: 144  0
LCD Errors: 0  0
Total Cells: 1508778825  0
Data Cells: 54271660  0
Bit Errors: 0  0
Some people suggest that rebooting the router at an off peak time could help but I have steered clear of rebooting unless there is no internet at all.  Roll eyes
Thanks in advance for any further help.
Smiley
VileReynard
Seasoned Pro
Fixes: 10
Probably you have a low error level(?) - you will have to try some before/after speed tests.
See http://www.kitz.co.uk/adsl/linestats_errors.htm
Fixes: 52
The number of RS Correctable Errors seems significant. With interleaving off these would become uncorrectable errors requiring retransmission - slowing down throughput.
However it's worth trying interleave off to see how you get on.
David
James
I'd be inclined to leave interleaving on based on the number of uncorrected errors.
TornadoRush
Thanks for the help. I found the pages at Kitz a useful source of info and now I have a better understanding of the stats I will see what happens with the interleaving off option.  Thanks  Smiley
James
Hiya,
I've placed the order for you now Smiley
TornadoRush
Thank you    Grin
James
How is it behaving today?
TornadoRush
Hi
Had to reboot the router once, but its been stable for a couple of days and the speed difference is great.  I am getting nice low pings of 25ms which, along with a recent regrade of my line has brought my ping down from 75 to 40 and now after you switched interleaving off, 25 which is spot on. Played some PS3 games like UT3 where the ping times are crucial and I definately have the edge speed wise. I am not aware of problems with packet loss. The router stats show:
Mode: G.DMT
Type: Fast
Line Coding: Trellis On
Status: No Defect
  Downstream Upstream
Rate (Kbps): 5280  832
SNR Margin (dB): 6.4  10.0
Super Frames: 5883538  5883536
Super Frame Errors: 5916  89
RS Words: 0  0
RS Correctable Errors: 0  0
RS Uncorrectable Errors: 0  N/A
HEC Errors: 2428  55
OCD Errors: 16  1
LCD Errors: 0  2
Total Cells: 1245528562  0
Data Cells: 24523923  0
Bit Errors: 0  0
Total ES: 2559  0
Total SES: 38  0
Total UAS: 14  0
I think it has been beneficial to switch interleaving off and seeing as the line is stabilising I think this will be good.  I take it the stats aren't showing anything negative to suggest otherwise?
Thanks for your help with everything.
VileReynard
Seasoned Pro
Fixes: 10
The errors are good.
But wait a few weeks/months and BT will decide your equipment is **** and can only connect at sluggard-speed.
I'd recommend that you do regular speed tests (and ping tests if this is important to you).
