BT Speed Checker - Further diagnostics not working
- BT Speed Checker - Further diagnostics not working
02-05-2014 11:27 PM
Hello,
Whenever I try the further diagnostics on the BT wholesale speed checker I get:
"Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information."
Why would that be?
Sam
Why would that be?
Sam
Message 1 of 5
(918 Views)
4 REPLIES 4
Re: BT Speed Checker - Further diagnostics not working
03-05-2014 10:39 AM
Sam,
Are you on fibre? If yes, I think this is the TAP3 test which has been broken for weeks. There is no forecast of when BT wholesale will have their test system fixed.
Kevin
Kevin
Message 2 of 5
(583 Views)
03-05-2014 12:06 PM
This is the PT (i.e. getting your IP Profile).
There are known issues with it and BT are suppose to have them fixed in some rolled out updates in a couple of weeks.
Message 3 of 5
(583 Views)
03-05-2014 12:30 PM
Message 4 of 5
(583 Views)
03-05-2014 5:31 PM
Hello,
-Sam
-Sam
Message 5 of 5
(583 Views)
