BT Performance Tester keeps failing
- BT Performance Tester keeps failing
- « Previous
- 1
- 2
- Next »
Re: BT Performance Tester keeps failing
27-11-2009 1:40 PM
Still not working for me. Could it be something to do with the switch over to ASDL2 which was programmed to take place today?
Message 16 of 22
(464 Views)
27-11-2009 2:49 PM
It worked at long last but I noticed that the BT IP Profile for my line was down to 6500 Kbps from 7000 Kbps whereas my DSL Connection Rate was up to 9120 Kbps downstream from 8096 Kbps.
My Plusnet Profile is still 7000 Kbps. Is this to do with the switch to ADSL2. I was hoping to see an increase in my speed.
Message 17 of 22
(464 Views)
27-11-2009 4:22 PM
When did your sync speed increase? On a 9120 sync you should get an 8000 profile sooner or later.
Message 18 of 22
(464 Views)
27-11-2009 4:45 PM
It must have been this morning. I was disconnected at 11.28 am this morning for around 5 minutes and I thought that might be the switch over to ADSL2. Then I read Bob's Service Status posting:
so I was unsure whether I was disconnected because of that or not. I hadn't been up for long so hadn't checked which gateway I was connected to.
I would be grateful anyway on an update on my position. Has my switchover to ADSL2 been completed? If so when can I expect an increase in speed?
Quote At approximately 11.00am this morning customers connected to two of our central pipes were inadvertently disconnected from the Internet
Message 19 of 22
(464 Views)
27-11-2009 4:55 PM
If you're syncing at 9120 then you're on ADSL2+.
Your profile will update over the next couple of days, but are in the 10 day settling in period again, so speeds may fluctuate.
I'd recommend routing every couple of days (early - mid morning).
Message 20 of 22
(464 Views)
27-11-2009 5:04 PM
Quote from: Mand
By this do you mean rebooting the computer to change the gateway or a reboot of the router?
Message 21 of 22
(464 Views)
28-11-2009 11:12 PM
Just run the BT Speedtester with the following result:
Download speedachieved during the test was - 1794 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Additional Information:
Your DSL Connection Rate :8096 Kbps(DOWN-STREAM), 440 Kbps(UP-STREAM)
IP Profile for your line is - 2000 Kbps
Why has my profile dropped to 2000 Kbps. I 'm now on ADSL2+ on Plusnet Premier and my Plusnet Profile still shows as 7000 Kbps.
Will the BT profile rise during the next 10 days, and why has it dropped to 2000 tonight? Can someone from Plusnet please advise.
Message 22 of 22
(464 Views)
- « Previous
- 1
- 2
- Next »
