BT Performance Test
- BT Performance Test
Re: BT Performance Test
26-08-2014 7:45 PM
Quote from: AndyH But you can kind of figure out your IP Profile from doing a speed test and checking the PN line speed.
Sync Rate 79987K -> BT IP Profile -> 77.42Mbps (am I correct?)
79987K x 96.79% = 77.42Mbps
77.42Mbps divide that by 0.9679 equal 79987K
26-08-2014 7:49 PM
I'm sure Andy can confirm
26-08-2014 7:50 PM
by dividing by 1.033 so a sync speed of 79987kbps translates to an IP profile of 77.42Mbps
which gives a Plusnet figure of 77.42Mbps
26-08-2014 7:52 PM
Quote from: Anotherone Well your calculator is almost as good as mine. I think the Profile gets rounded up, so it would be 72.43Mbps.
What is your calculator would be?
26-08-2014 7:57 PM
Oh, btw, the Current Line speed gets rounded down so it may only be 72.4
26-08-2014 9:51 PM
27-08-2014 12:26 AM
Quote from: Townman ROLMFO
Roll On Laughing My Floor Off???
27-08-2014 7:17 AM
You really must get a good calculator goldenfibre, even google does the job better
Quote from: goldenfibre by dividing by 1.033 so a sync speed of 79987kbps translates to an IP profile of 77.42Mbps
OK Mr.Pedant, 79.987 divided by 1.033 = 77.43175218 which when rounded to 2 decimal figures is 77.43, so the Plusnet Profile will be 77.4.
NB. I can find no absolute proof (atm) that 1.033 is the exact figure but that one does come from reliable sources and fits with what most people see.
27-08-2014 8:26 AM
Quote from: Jaggies
Roll On Laughing MyFloorOff???
Face! Brian
02-09-2014 2:20 PM
02-09-2014 2:24 PM
02-09-2014 2:26 PM
Quote from: AndyH I've heard that if you don't use the internet for a few days (or maybe a week), then it will work again. I recommend you try this
I try it today after leave it alone for a week. But still the same. No good. I give up!
03-09-2014 3:00 PM
08-09-2014 12:14 PM
08-09-2014 12:18 PM
