BT Performance Test
- BT Performance Test
Re: BT Performance Test
20-08-2014 4:46 PM
see below!
21-08-2014 2:41 PM
Just thought I would give you all a quick update to let you know that BT have released information that details a fix is incoming for the TAP3 Diagnostics Test in an upcoming round of improvements. This should be due over the course of the next few months and we'll provide some more exact dates as we get them!
21-08-2014 2:42 PM
21-08-2014 2:43 PM
Thanks for the update.
The next few months They said that last time back in April or May (to be fixed in June) but nothing happened. I'd like to be optimistic, but past indicators are a guide of future performance when it comes to the BTW Speed Tester.
21-08-2014 2:46 PM
21-08-2014 2:56 PM
I totally understand the scepticism but I've seen the resource allocation so I don't see why this wouldn't go ahead given that this information release has gone out to all their customers.
21-08-2014 3:03 PM
22-08-2014 5:09 PM
After two attempts.
1. Best Effort Test:
Download Speed : 49.46 Mbps
2. Upstream Test:
Upload Speed : 13.64 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
22-08-2014 5:21 PM
22-08-2014 5:21 PM
BT are useless.
22-08-2014 5:23 PM
22-08-2014 5:58 PM
22-08-2014 6:00 PM
Quote from: goldenfibre @ buseng12 try that - https://windows.mouselike.org/be/index.asp?DoAction=BrasChecker
Thank you, that worked.
Anotherone, my connection is 6 months old & have used the BTW tester before ok.
22-08-2014 7:06 PM
22-08-2014 7:48 PM
