BT Offer
- BT Offer
BT Offer
29-03-2013 6:11 PM
Re: BT Offer
29-03-2013 6:20 PM
Re: BT Offer
30-03-2013 8:29 AM
Re: BT Offer
30-03-2013 10:55 AM
If it's available and you aren't on it, Plusnet can move you to it if you request it here.
Re: BT Offer
30-03-2013 11:34 AM
Just had a quick look over your line. I can confirm that you're already on ADSL2+ - Your line estimate is 9Mbps with speeds ranging between 7.5 and 11Mbps.
It may be worth looking through our "slow speeds" guide to try and increase your sync speed.
If you're currently getting 4Mbps, this is below the line estimate. I'd try the router plugged directly into the main socket (test socket preferred) with a replacement microfilter and then log-in to your router to see the sync speed to the exchange.
You can do this by going to http://192.168.1.254 and entering the username as "admin" and the password as the serial number of the router starting with CP - Entered in capital letters.
If the sync speed increases when plugged into the main/test socket - This may point towards an issue with the extension cabling (if you're not already in the main socket).
If you find the sync speed hasn't increased after doing this, I'd suggest raising a speed fault
Hope this helps,
Regards,
Matt
Re: BT Offer
30-03-2013 1:02 PM
Do you have a Master Socket like the one on the left? If so - are you plugged into the Test Socket?
Also to get the Stats, as shown by Matt, login into your modem/router and under DSL Connection, click View more ..... as shown here and then Details on the top RHS. Just Copy and Paste the information into a post.
Re: BT Offer
30-03-2013 6:00 PM
Uptime: 0 days, 8:52:42
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 1,147 / 6,112
Output Power (Up/Down) [dBm]: 12.0 / 0.0
Line Attenuation (Up/Down) [dB]: 12.0 / 30.5
SN Margin (Up/Down) [dB]: 6.5 / 6.5
Loss of Framing (Local/Remote): 91 / 0
Loss of Signal (Local/Remote): 12 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 245 / 0
FEC Errors (Up/Down): 4,294,967,265 / 0
CRC Errors (Up/Down): 4,294,967,265 / 231
HEC Errors (Up/Down): 1 / 149
I hope this is the information is right I am, plugged into the first main socket that comes into my house there is no test socket.
Re: BT Offer
30-03-2013 7:05 PM
Re: BT Offer
30-03-2013 9:05 PM
Quote from: valart I am, plugged into the first main socket that comes into my house there is no test socket.
How are you extension sockets wired into the main socket? Is it possible to disconnect them?
Re: BT Offer
30-03-2013 9:37 PM
You ought to be able to get around double what you are getting. My guess from your previous posts is this is to do with your internal wiring.
Do you have a digital camera perchance? If so, if you could unscrew the second socket so that you can see the colour of the wires and the terminal numbers they are connected to (be careful not to pull them out).
If you can take a photo so that the wire colours and terminal numbers are clear, otherwise just describe the colours and the terminal numbers they are connected to.
Re: BT Offer
30-03-2013 9:39 PM
Re: BT Offer
30-03-2013 9:46 PM
Re: BT Offer
30-03-2013 9:50 PM
Edit: To add an attachment to a post, if you didn't use the Reply button, when you've typed the message, click on Preview, then below the box you'll see the + Additional Options and Attachments..., click on the plus then Browse to where you saved the .jpg
Re: BT Offer
31-03-2013 4:21 AM
Quote from: valart Link Information
There is something wrong with your line. You had the same line attenuation as mine with 30.5dB. Is your router closer to the master socket and make sure your router cable plugged into BT test socket with a short cable under 1 metre is best. And get a good ADSL filter. And try again. I did brought a short cable 0.5 metre and adslnation faceplate and a very good high performance router did increase my ADSL2+ as following:
ADSL Link Downstream Upstream
Link Rate 17659 Kbps 1270 Kbps
Line Attenuation 30.5 dB 16.8 dB
Noise Margin 3.1 dB 6.2 dB
Re: BT Offer
31-03-2013 7:32 AM
Quote from: valart it looks like I am paying for slow broadband
If you don't plan to do anything about it then you are settling for slow broadband. No ISP that I know of will intervene free-of-charge if a speed problem is down to your internal wiring (as is most likely the case here). But the remedy is unlikely to be very difficult and if you can provide details of your wiring then people on the forum will tell you what to do.
