BT-OR engineer left hours ago. Still at 10Mbps. Was hoping for more.
- BT-OR engineer left hours ago. Still at 10Mbps. Wa...
10-01-2013 9:35 PM
Got connected to fibre broadband this afternoon. Did an initial speed test at about 10Mbps. Just done another and it's still the same.
Am I being a bit optimistic and impatient to expect faster speeds so early on? Or is there a problem?
Message 1 of 6
(1,189 Views)
5 REPLIES 5
Re: BT-OR engineer left hours ago. Still at 10Mbps. Was hoping for more.
10-01-2013 9:46 PM
If you moved from an ADSL package on Plusnet, the profile on Plusnet's systems might still be set to your old speed.
Compare the IP profile from the BTW Performance Test here:
http://www.speedtest.btwholesale.com/
(you have to perform the additional tests after the first set, to see the IP profile)
to the Plusnet profile here:
Message 2 of 6
(600 Views)
10-01-2013 9:59 PM
Cheers CX,
I've run the BTW test, and got this result:
1. Best Effort Test:
Download Speed : 6.02 Mbps
2. Upstream Test:
Upload Speed : 5.32 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
I ran the test again and got the same result.
This is the Plusnet profile:
Estimated line speed:
58Mb (Accurate to within +/- 1Mbit) - Checked on 2012-12-06 17:20:38
Current line speed:
11.7 Mb
2. Upstream Test:
Current line speed:
11.7 Mb
Message 3 of 6
(600 Views)
10-01-2013 10:30 PM
Thanks for the information via PM. I'll get this looked at that first thing tomorrow morning for you
Message 4 of 6
(600 Views)
11-01-2013 2:19 PM
I tried to call you this morning but you were unavailable to take my call. When you have a bit of free time, can you please run another Speed Test?
Everything looks fine on your account now and want to know if the issue is still outstanding.
Message 5 of 6
(600 Views)
11-01-2013 6:55 PM
CX you were right. I called Plusnet this afternoon, to find I was still on the ADSL profile. Now on fibre profile- 65Mbps!
Message 6 of 6
(600 Views)
