BT IP profile stuck on 135k
Alxns
How long to recover folks?
PN profile - 3500K
Uptime: 0 days, 17:15:31
DSL Type: G.992.3 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 888 / 4.792
Bandwidth (Up/Down) [kbps/kbps]: 888 / 4.216
Data Transferred (Sent/Received) [MB/MB]: 52,45 / 86,63
Output Power (Up/Down) [dBm]: 12,5 / 19,0
Line Attenuation (Up/Down) [dB]: 24,0 / 45,5
SN Margin (Up/Down) [dB]: 12,5 / 13,0
Loss of Signal (Local/Remote): 3 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 3 / 0
FEC Errors (Up/Down): 913 / 159.690
CRC Errors (Up/Down): 0 / 107
HEC Errors (Up/Down): 0 / 189
jojopillo
Re: BT IP profile stuck on 135k
Hi KyleS,
It's now showing 3500 on both PN & BT systems. Are you seeing the relative speed now?
Jojo Smiley
Alxns
Yup i sure am.
jojopillo
Hi KyleS,
can you reboot and do another speed test. ASAP as there's someone I would need to contact before COB.
Jojo Smiley
Alxns
I just get this message
'The system is currently busy. Please try again shortly, however if this problem persists, raise the issue with your service provider'
i'll try again shortly
also
this is what i'm getting from the recommend speedtest site
jojopillo
Hi KyleS,
Ok, that would now seem consistent with your 3500k profile.
Jojo Smiley
